Does anyone know how to remove the rear conter console?
Hi guys,
Does anyone know to how remove the rear center console.
I got most the part unclipped but can't take off the shifter for tiptronics???
Thanks for your valuable input!
Download the PDF file at the bottom of the page. Theres some good instructions on how to remove the console.
http://www.bmracing.com/index.php?id...cat=15&pid=187
Here you go.
Removing:
Lever the locking button A off with a suitable tool or finger. The locking button must be pressed so that the tool can be inserted between the selector lever B and locking button. (The ignition key must be in position 1 before the locking button can be pressed.)
2. Remove compression spring A and pull spring clip B off toward the rear.
3. Pull selector lever up and off.
Installing:
1. Assemble the selector **** with spring clip, compression spring and locking button. Fit conical compression spring with the small diameter facing the guide peg.)
2. Press the complete selector **** onto the shift lever until it bottoms. The spring clip must fully engage in the slot on the selector lever.
3. Check function of locking button.
Removing:
Installing:
I'mAllIn
Sep 11, 2015 06:38 AM
