Upsolute Dyno Graph
Old Feb 26, 2004 | 09:29 AM
StephenTi's Avatar
StephenTi is infamous around these parts
Upsolute Dyno Graph
Mods: Upsolute Chip, Cargraphic Exhaust, KN filter. Pump Gas (93 oct).
Dyno'd on a Dynojet with front driveshaft disconnected.
Both technicians working on the car claimed that there was slippage on the run. However, I didn't detect any.
Old Feb 26, 2004 | 09:36 AM
All Boost's Avatar
All Boost is infamous around these parts
Was this on pump gas? If so, was it 91, 92, or 93 octane?
Were these results measured at the rear wheels or at all four wheels?
Thanks!
Marc
Old Feb 26, 2004 | 09:52 AM
StephenTi's Avatar
All Boost... I edited my post with the answers to your questions.
Old Feb 26, 2004 | 11:21 AM
ebaker's Avatar
ebaker is infamous around these parts
Is that graph too rich at higher RPM?
Old Feb 26, 2004 | 11:36 AM
Chordate's Avatar
Chordate is infamous around these parts
So a non upsolute Turbo produces more HP after 5300 RPM?
Old Feb 26, 2004 | 11:41 AM
Dock (Atlanta)'s Avatar
Dock (Atlanta) is just really niceDock (Atlanta) is just really niceDock (Atlanta) is just really niceDock (Atlanta) is just really niceDock (Atlanta) is just really nice
What was the maximum boost?
Old Feb 26, 2004 | 11:47 AM
AeroTT's Avatar
AeroTT is infamous around these parts
Old Feb 26, 2004 | 12:03 PM
All Boost's Avatar
Looks like 12:1 A/F in the higher RPMs. This is a little on the rich side, but nothing to be concerned with since most turbocharged and supercharged cars from the factory run a LOT richer than that! They like to richen the mixture a little in the high RPMs to prolong the life of the turbo(s). From my experiences, there is very little HP gain in leaning out a force induction car from 12:1 to say 12.5:1 or 13:1.
Marc
Old Feb 26, 2004 | 12:12 PM
Chordate's Avatar
Originally posted by AeroTT
Ooops, I made a mistake. Nevermind then.
Old Feb 26, 2004 | 12:23 PM
Rave TT's Avatar
Happy Now?
Rave TT is a jewel in the roughRave TT is a jewel in the roughRave TT is a jewel in the rough
I'm such a noob, does 454 to the wheels mean the car is 554 hp?
Old Feb 26, 2004 | 12:44 PM
dbelleperc's Avatar
I soon will be a supporting member
dbelleperc is infamous around these parts
Rave they said that the front driveshaft was disconnected so you would multiply the 454 by 15-17% instead of the usually 22-24% for a AWD Turbo, I got 522-531 HP at the flywheel.
Old Feb 26, 2004 | 12:54 PM
Rave TT's Avatar
Happy Now?
I seek, thanks.
Old Feb 26, 2004 | 01:23 PM
All Boost's Avatar
I highly doubt the driveline loss of a 996TT with the front driveshaft disconnected is 15-17%. MAYBE if it were automatic, I'd believe it. But most modern RWD stickshift cars lose only ~12%. Therefore, it's about 508-509 flywheel horsepower. Still not too shabby. :-)
Old Feb 26, 2004 | 02:22 PM
LSM's Avatar
LSM
Senior Member
LSM is a glorious beacon of lightLSM is a glorious beacon of lightLSM is a glorious beacon of lightLSM is a glorious beacon of lightLSM is a glorious beacon of lightLSM is a glorious beacon of light
Evo uses the same dyno when they dyno their cars. They also disconnect the front drivetrain. Correction factor 1.15%
454.9 HP = 523hp at the crank
504.8lb/ft=580lb/ft at the crank
Old Feb 26, 2004 | 02:53 PM
All Boost's Avatar
I thought that Evo's Dynojet was RWD while the one at the Porsche Exchange was AWD? That right there could skew numbers since they're not the same dyno.
Seems kind of pointless that a Porsche shop would spend the extra money for an AWD dyno when most of the AWD cars that they service wind up disconnecting the front driveshafts anyway because the AWD Dynojet is not the type of AWD dyno that Porsches should be used to dyno on. I've heard of Porsches blowing center differentials when dynoed in "AWD mode" on AWD Dynojets. So why would the Porsche Exchange go and purchase an AWD Dynojet? Seems like a waste of money...they should have went with the AWD Mustang dyno that GIAC and AWE use!
