GT3 Look Wheels from GT2/Turbo S Size Question
What sizes where the GT3 look wheels that came on the GT2/Turbo S? I may buy a set but before I do I wanted to make sure on the sizes.
I have set they are 8.5" and 12" x 18" the offsets are much different than the turbo, GT3 version. I think the fronts maybe the same but the offset and width are wider on the GT2 version. The version that came on the TurboS and the GT2 are different.
Oak: Are you saying the GT3 wheels on the Turbo/Turbo s are 18x8 and 18x11 and the GT3 wheels on the GT2 are 18x8.5 and 18x12? If so I need to make sure which ones I am considering since I am selling my GT2 size tires with my Work Wheels but have stock size Pirellis.
Oak is correct!
GT2's with GT3 or Turbo II styles have:
- 18x8.5 fronts with 40mm offset
- 18x12 rears with 45mm offset
- 18x8 w/50mm offset
- 18x11 w/45mm offset
Originally Posted by zona
Oak is correct!
996TT's with GT3 or Turbo II styles have:
Well......................
You either need a new ruler
or
someone swapped out your lighter TT wheels with heavier GT2 wheels!
Easy to verify-
or
Easy to verify-
- GT2 wheels are solid spoke not hollow
- the inside of the wheels will be stamped with the width, diameter, offset and part number
- if your measuring edge to edge, that is not the way Porsche measures their wheels. They measure inner bead to inner bead surface
- the GT2 part number is 996.362.136.31 for the 8.5x18
- the TT part numbers are 996.362.136.01 for solid spoke and 996.362.136.04 for hollow-8x18
Originally Posted by wross996TT
Sorry...how do you explain the ones I have that came from the factory with those sizes I already posted? 18X8.5 and 18X11?
ModBargains
Audi Vendor Classifieds
Sep 1, 2015 05:26 PM
ModBargains
Aug 20, 2015 12:28 PM
PelicanParts.com
GT3/GT2/GT Vendor Classifieds
Aug 18, 2015 03:42 PM
PelicanParts.com
997 Turbo Vendor Classifieds
Aug 18, 2015 03:41 PM
PelicanParts.com
997 Vendor Classifieds
Aug 18, 2015 03:39 PM
