UMW Stage 3A Zero Clearance Breaks New Ground: Dyno Sheet
Subscribe
Jan 20, 2007 | 02:00 PM
  #151
Wow, stay away from the board for a day and look what happened ...you guys are all nuts...like me. Kevin
Reply
Jan 20, 2007 | 02:19 PM
  #152
Quote: NEGATIVE. I posted "800 HP" because apparently both you and DMK have previously stated that it dyno'd 700 HP to the wheels (as seen below), which would mean 800+ crank HP. It had absolutely NOTHING to do with the time(s) it ran.
Just to be clear, I'm never going to post "700 HP" to describe a car that actually makes 800 HP, regardless of which tuner built the car.
https://www.6speedonline.com/forums/...0&postcount=58
https://www.6speedonline.com/forums/...35&postcount=8
I have every intention of keeping the 1/4 mile and 60-130 lists as accurate as I possibly can, because if they're not accurate, I don't believe there's any reason for them to even exist. If that pisses a few people off, so be it.
Not to push the buck my numbers came from the tunner, If thats what they tell me then that is what it is. Am I incorrect in this?
Reply
Jan 20, 2007 | 04:12 PM
  #153
Well, I have a confession to make... I am splitting my case and sending it out to be bow-tailed and shufflepinned. I am adding a 9000rpm GT3RS crank that has the oiling capabilities to handle these levels. The crank will be cross drilled and the oil galleries in the case enlarged for proper oiling. The entire rotating assembly will be balanced from the flywheel to the crank pulley. This will lay the foundation for the TopSecret UMW stg4 .... this is too cool. Need less to say there are some parts that will be available soon..like an 18K mile crank. Pics to follow. Kevin
Reply
Jan 20, 2007 | 04:15 PM
  #154
Kevin are you really that bored?
Reply
Jan 20, 2007 | 04:16 PM
  #155
Quote: Kevin are you really that bored?
It's a sickness... but I choose to live with it instead of medicating myself
Reply
  #156
Quote: Well, I have a confession to make... I am splitting my case and sending it out to be bow-tailed and shufflepinned. I am adding a 9000rpm GT3RS crank that has the oiling capabilities to handle these levels. The crank will be cross drilled and the oil galleries in the case enlarged for proper oiling. The entire rotating assembly will be balanced from the flywheel to the crank pulley. This will lay the foundation for the TopSecret UMW stg4 .... this is too cool. Need less to say there are some parts that will be available soon..like an 18K crank. Pics to follow. Kevin
Sweeeeeet! These cars are FREAKIN money pits!
Reply
Jan 20, 2007 | 04:23 PM
  #157
Reply
Jan 20, 2007 | 04:29 PM
  #158
MY boy, please lay off the crack pipe!!!
Reply
Jan 20, 2007 | 04:42 PM
  #159
Quote: MY boy, please lay off the crack pipe!!!
Tom, my friend...this no joke. You know what to do...
Reply
Jan 20, 2007 | 04:48 PM
  #160
Quote: Tom, my friend...this no joke. You know what to do...
I believe you. Lets compare notes for stage4...
Reply
Jan 20, 2007 | 04:50 PM
  #161
Quote: I believe you. Lets compare notes for stage4...
Vincent....those notes led me to believe I may need , not just want, a 9000rpm crank...Kevin
Reply
Jan 20, 2007 | 04:56 PM
  #162
Here's my teaser to 9K rpm heaven..
Reply
Jan 20, 2007 | 05:00 PM
  #163
I hate you all hahahah
Reply
Jan 20, 2007 | 05:18 PM
  #164
You Guys!! unreal!! out of your minds!! F*ck!! does 6speed have a local shrink!!
Reply
Jan 20, 2007 | 05:20 PM
  #165
Youve been Holding out!! If you cant trust your Dentist, who can you trust
Quote: Here's my teaser to 9K rpm heaven..
Reply
