UMW Stage 3A Zero Clearance Breaks New Ground: Dyno Sheet
Old Jan 21, 2007 | 10:36 AM
  #211
KPG's Avatar
KPG
KPG Is a GOD !KPG Is a GOD !KPG Is a GOD !KPG Is a GOD !KPG Is a GOD !KPG Is a GOD !KPG Is a GOD !KPG Is a GOD !KPG Is a GOD !KPG Is a GOD !KPG Is a GOD !
Originally Posted by cjv
Kevin, see the machine grindings on the top of the pump? Those are clearance grinds for the crank and rods.
Chad , I realize the pump needs to be profiled, but I need to ask what may be a naive question. How can an oil pump cost 10K....that is criminal
Old Jan 21, 2007 | 10:56 AM
  #212
iLLM3's Avatar
That's for damn sure
Old Jan 21, 2007 | 11:01 AM
  #213
Acropora's Avatar
Acropora has a spectacular aura aboutAcropora has a spectacular aura about
I think the gt3r pump doesn't pump any more at all than the stock one but rather has two pickups? You might have to run slicks pulling high lateral g's to notice a difference?
So now, how about the head porting and bigger valve work. While you're in there......lol.
Old Jan 21, 2007 | 11:31 AM
  #214
KPG's Avatar
KPG
Brad....you are way behind the curve, The headsa re being ported and high rpm springs and titanium retainers added....I like my stock valves, so I am keeping them. I dont want to get crazy
Old Jan 21, 2007 | 12:01 PM
  #215
wross996TT's Avatar
Originally Posted by robmd99
THIS POST IS HOT!!!!!!!! I AM VERY HAPPY WITH ALL THE PROGRESS ALL OF THE TUNNERS ARE MAKING!!! I LOVE COMPETITION!!! I WOULD LOVE TO HAVE A TURBO THAT FEELS LIKE A GT3 AND RUNS WITH THE ***** OF A TURBO AND MY FRIENDS THIS MOTOR SOUNDS LIKE IT!!! ONE QUESTION CAN YOU DO THIS PROJECT BUT WITH A 3.8 MOTOR?? THANKS TO ALL FELLOW 6SPEEDERS!!!!!!!!!!
No need to shout...
Old Jan 21, 2007 | 12:06 PM
  #216
KPG's Avatar
KPG
Rob, I think you are right...This will improve on the massive low end grunt at 2k rpms of the 3A dyno sheet of 400 ftlbs with the addition of the heads and rods...The crank and case machiningwill allow much higher rpms up top with no oiling issues..I have total confidence that this will be the best of both worlds. I am just happy to be in on the ground floor with this project, it is a once in a lifetime opportunity...Why would you need a 3.8? More TQ....this will have plenty. Kevin
Old Jan 21, 2007 | 12:10 PM
  #217
topgun's Avatar
topgun Is a GOD !topgun Is a GOD !topgun Is a GOD !topgun Is a GOD !topgun Is a GOD !topgun Is a GOD !topgun Is a GOD !topgun Is a GOD !topgun Is a GOD !topgun Is a GOD !topgun Is a GOD !
Show off
Old Jan 21, 2007 | 12:18 PM
  #218
robmd99's Avatar
robmd99 has a reputation beyond reputerobmd99 has a reputation beyond reputerobmd99 has a reputation beyond reputerobmd99 has a reputation beyond reputerobmd99 has a reputation beyond reputerobmd99 has a reputation beyond reputerobmd99 has a reputation beyond reputerobmd99 has a reputation beyond reputerobmd99 has a reputation beyond reputerobmd99 has a reputation beyond reputerobmd99 has a reputation beyond repute
THIS PACKAGE SOUND LIKE IT WILL BE A 9.9 1/4 MILE IN A GT2?
Old Jan 21, 2007 | 12:26 PM
  #219
topgun's Avatar
From your mouth to GODS ears!!!
  #220
Divexxtreme's Avatar
Kevin,
We should be seeing some dyno numbers from Todd's new DynaPack soon.
OhioGT2's car has the same setup as my previous bolt-on setup...but he's using GT30's instead of the entry-level K24/18g's that I had. His car will hopefully be on the dyno next week.
WHP #'s should be similar to the 3A, so it should make for a more accurate comparison.
Congrats on the upgrades. Now is definitely the time to do it. Things are looking more interesting for Tulsa every day.
Old Jan 21, 2007 | 12:36 PM
  #221
There might be a general misconception about the k24/18s... it seems like we all try to compare every other set up to it since Scott had so much success at the track. I would liek to point out that these turbos are the most affordable... entry level k24 based turbos. The beauty of Protomotive is that they can put together ANY turbo combination per customer's request. if u want gt28rs, gt30rs, gt35r... k24/20gs... or any other combo... it can and is being done.
Todd is the only, to my knowledge, tuner that water cools all of the Garrett GT based turbos...
The reason Todd is not obligated to sell only one or two type of turbo set ups is becasue he is also a programmer... thus it gives him flexibility.
I can go back to him right now and upgrade my GT35Rs to 76 mm lightweight compressors and Todd will do the dyno tuning... NO PROBLEM.
The cost of upgrading K24s to 18gs is less then silicone hoses other respectable tuners sell... how can you go wrong with that...
If a customer wants a Quicker spooling turbo one must share that with Todd during the early stage of the design process.
just my opinion...
markski
2001 996TT 3.6L and stock ECU
9.66
seconds @ 147.76 mph 1/4 mile
click to view
Old Jan 21, 2007 | 12:38 PM
  #222
KPG's Avatar
KPG
Originally Posted by Divexxtreme
Kevin,
Not sure what you mean about accurate comparisons...I assume the 18G 700 kit is priced similar to the 3A at 21K....so If you are using GT30's that would make for a more expensive kit and a not so accurate comparison. Are we allowed to compare RWD to AWD now? In the other post you were critical of that....I agree, now certainly is the time, if at all... Kevin
Old Jan 21, 2007 | 12:55 PM
  #223
vincentdds's Avatar
vincentdds has a reputation beyond reputevincentdds has a reputation beyond reputevincentdds has a reputation beyond reputevincentdds has a reputation beyond reputevincentdds has a reputation beyond reputevincentdds has a reputation beyond reputevincentdds has a reputation beyond reputevincentdds has a reputation beyond reputevincentdds has a reputation beyond reputevincentdds has a reputation beyond reputevincentdds has a reputation beyond repute
A 1000hp GT2 that will rev like a GT3 is a god's gift to mankind.
Old Jan 21, 2007 | 01:07 PM
  #224
What I mean is the way that DynaPacks an DynoJets show torque. DynaPacks allow low speed boost onset whereas Dynojets tend to show later boost onset than you actually see on the road. Thus, a DynaPack is more accurate when it comes to torque measurements.
As far as the price difference between GT30s' and K24/18's, it's very small.
What I was primarily critical of was the comparisons between two different types of dynos, on two systems that don't make similar power. The 3A system uses a much larger turbo than a K24/18G system does, and obviously makes more power. But yes, reverse engineering the wheel HP numbers is another variable in and of itself.
Anyway, the GT30 setup will make more power than mine did, and will be dyno'd on a DynaPak just like the 3A was. I thought you'd be happy to hear this since it seems you want to compare numbers to a similarly built Proto car. If I'm mistaken, I apologize.
I think you're absolutely doing the right thing upgrading. You'll be happier in the long run.
Old Jan 21, 2007 | 01:25 PM
  #225
SMR's Avatar
SMR
SMR is a jewel in the roughSMR is a jewel in the roughSMR is a jewel in the roughSMR is a jewel in the rough
just my opinion...
markski
I would love some turbos from Proto but im no fan of a BC on this car so, thats why i wan't go proto
