Leak Oil Intercooler?? PLEASE HELP!!
Old Jan 29, 2007 | 01:43 PM
ritzy996tt's Avatar
ritzy996tt is infamous around these parts
Unhappy Leak Oil Intercooler?? PLEASE HELP!!
Hi, I am some what new to the forum and I've searched for this problem but can’t find an answer.
My 996tt (2003) is leaking oil very little! From the passenger side, the oils seems to be very clear so I don’t know where is coming from is right under the bumper. I've also noticed that the gears will not engage until I completely let go the clutch (don’t know if the problems are related)
Does anyone have an idea of what it is? How hard is it to remove the plastic protectors from the bumper to see the leak?
Thank you for any reply.
JP
Old Jan 29, 2007 | 02:41 PM
K2@Brandywine's Avatar
K2@Brandywine is infamous around these parts
JP, where exactly on the car is the fluid leaking from? What exact color is the fluid, and does it have a smell?
Kevin H
Old Jan 29, 2007 | 06:38 PM
ritzy996tt's Avatar
The leak is right under the side front bumper infront of the passenger side front tire. It looks yellowish like brand new motor oil, it does not have a strong smell.. it seems like its coming from the small radiator located inside the bumper, or at least is what I think.. I will go downstairs and take a picture of the oil and the side where is coming out and post it here..
Old Jan 29, 2007 | 07:29 PM
steve harris's Avatar
steve harris Is a GOD !steve harris Is a GOD !steve harris Is a GOD !steve harris Is a GOD !steve harris Is a GOD !steve harris Is a GOD !steve harris Is a GOD !steve harris Is a GOD !steve harris Is a GOD !steve harris Is a GOD !steve harris Is a GOD !
souhds like coolento me, looks like coolent must be coolent (how do you spell coolent?) most likly a loses hose goot luck
Old Jan 29, 2007 | 08:57 PM
porschespeeddemon's Avatar
porschespeeddemon Is a GOD !porschespeeddemon Is a GOD !porschespeeddemon Is a GOD !porschespeeddemon Is a GOD !porschespeeddemon Is a GOD !porschespeeddemon Is a GOD !porschespeeddemon Is a GOD !porschespeeddemon Is a GOD !porschespeeddemon Is a GOD !porschespeeddemon Is a GOD !porschespeeddemon Is a GOD !
Coolant...Most likely the lower radiator hose, if it is indeed coolant.
Old Jan 29, 2007 | 09:00 PM
Yeh, it is definately coolant, have seen a few of those hoses come loose. You are going to have to remove that wheel to gain access to it, then it should be right there and easily gotten to.
Old Jan 29, 2007 | 09:55 PM
ritzy996tt's Avatar
Thank you everyone, I am going to have to check both sides it seems like its leaking from the right and left side of the car.. when i backed out the car from the garage the pottle was now in the right
I attached some pictures of the puddle of oil see if helps, I will remove the wheel tomorrow..
Old Jan 29, 2007 | 10:21 PM
ritzy996tt's Avatar
Old Jan 29, 2007 | 10:22 PM
ritzy996tt's Avatar
Old Jan 29, 2007 | 10:44 PM
Yep, thats coolant.
Old Jan 30, 2007 | 11:13 AM
Bruce's Avatar
Member
Bruce Is a GOD !Bruce Is a GOD !Bruce Is a GOD !Bruce Is a GOD !Bruce Is a GOD !Bruce Is a GOD !Bruce Is a GOD !Bruce Is a GOD !Bruce Is a GOD !Bruce Is a GOD !Bruce Is a GOD !
It's coolant
I had the exact same problem and it was a bad lower coolant hose, easy fix.
Old Jan 30, 2007 | 11:42 AM
ritzy996tt's Avatar
I am going to tackle the problem tonight!! thank you and will let everyone know how it goes. I think this started happening after I took it in to the dealer to get my front wheel drive repair, the axle snapped during a Dyno Run
Old Feb 2, 2007 | 10:01 AM
ritzy996tt's Avatar
Just to give everyone an update, I tried checking the leak myself but could not find the source.. I ended up taking it to the Dealer this morning lets hope they find it!! Will keep everyone posted.
Old Jun 21, 2007 | 05:03 PM
cpu77's Avatar
cpu77 is infamous around these parts
What did it end up being?
Old Jun 21, 2007 | 05:39 PM
ritzy996tt's Avatar
It was the front radiator it was bad, I bought a new one and replaced it in my garage!
