GT700. Does it need the internal mods?
Old Feb 13, 2007 | 05:53 PM
RennTechV12's Avatar
RennTechV12 has a reputation beyond reputeRennTechV12 has a reputation beyond reputeRennTechV12 has a reputation beyond reputeRennTechV12 has a reputation beyond reputeRennTechV12 has a reputation beyond reputeRennTechV12 has a reputation beyond reputeRennTechV12 has a reputation beyond reputeRennTechV12 has a reputation beyond reputeRennTechV12 has a reputation beyond reputeRennTechV12 has a reputation beyond reputeRennTechV12 has a reputation beyond repute
Originally Posted by SlowMotion
Is your CGT faster than your GT700? I love the way CGT's look and sound.
The GT700 pulls about 4 or 5 CLs on the CGT. The CGT will pull on the GT700 if it's caught at low revs.
Old Feb 13, 2007 | 06:13 PM
Highhats's Avatar
Highhats is a splendid one to beholdHighhats is a splendid one to beholdHighhats is a splendid one to beholdHighhats is a splendid one to beholdHighhats is a splendid one to beholdHighhats is a splendid one to behold
I have gt700/750 and put down over 680whp race all on stock internals. I beat the sh*t out of my car and I have no issues. GL
-Suman
Old Feb 13, 2007 | 06:16 PM
SlowMotion's Avatar
SlowMotion is infamous around these parts
-Suman
What kind of power does it make (or do you run a different tune) when on normal 92 octane?
Old Feb 13, 2007 | 08:11 PM
joetwint's Avatar
joetwint Is a GOD !joetwint Is a GOD !joetwint Is a GOD !joetwint Is a GOD !joetwint Is a GOD !joetwint Is a GOD !joetwint Is a GOD !joetwint Is a GOD !joetwint Is a GOD !joetwint Is a GOD !joetwint Is a GOD !
I meant split in the sense that the block splits in half to change the internals, and mine (like most I assume) hasn't been openened up yet.
We only have 92 octane here. Jags in running a GT700, not sure he has located unleaded race fule around here or not.
I have a better question! hehehe... why would a guy need TWO GT700's? Dang.
Find a VP race gas distributor in your area and buy it by the 55 gallon drum.They will deliver it to your house and you can quit searching for gas stations that carry race fuel. Its also a safer way because atleast you know your getting race gas and no one at the station mixed up the pumps.Good luck.
Old Feb 13, 2007 | 08:20 PM
jags911tt's Avatar
jags911tt Is a GOD !jags911tt Is a GOD !jags911tt Is a GOD !jags911tt Is a GOD !jags911tt Is a GOD !jags911tt Is a GOD !jags911tt Is a GOD !jags911tt Is a GOD !jags911tt Is a GOD !jags911tt Is a GOD !jags911tt Is a GOD !
I only use 101 from 76 in North Auburn.
Jag
Old Feb 13, 2007 | 09:21 PM
Dr_jitsu's Avatar
what is the cheapest price for VP 109 in 55 gallon drums?
I am paying 7 per gallon and getting 5 gallons at a time. When I will be in high boost I mix 2 gallons of vp 109 w/ 93.
That should protect my motor.
Old Feb 13, 2007 | 09:24 PM
KPG's Avatar
KPG
KPG Is a GOD !KPG Is a GOD !KPG Is a GOD !KPG Is a GOD !KPG Is a GOD !KPG Is a GOD !KPG Is a GOD !KPG Is a GOD !KPG Is a GOD !KPG Is a GOD !KPG Is a GOD !
I am sure you know , but VP motorsports 109 is actually 105 octane R+M/2...that is the same method for determining consumer octane ratings. Kevin
Old Feb 13, 2007 | 09:57 PM
geetee's Avatar
geetee has a brilliant futuregeetee has a brilliant futuregeetee has a brilliant futuregeetee has a brilliant futuregeetee has a brilliant futuregeetee has a brilliant futuregeetee has a brilliant futuregeetee has a brilliant futuregeetee has a brilliant futuregeetee has a brilliant futuregeetee has a brilliant future
Originally Posted by KPG
This bottom end will be able to take me to Markski type HP levels in the future. Kevin
Are there any plans?
Old Feb 13, 2007 | 10:13 PM
jags911tt's Avatar
Anyone have the contact info for VP?
Old Feb 13, 2007 | 10:41 PM
KPG's Avatar
KPG
of course...the main reason for the case machine work, heads, GT3 crank, oiling upgrades etc... is laying the ground work for the next round of mods... I should only need new turbos and fuel system upgrades and I can take it to the next level....wherever that may be Kevin
Old Feb 13, 2007 | 10:42 PM
KPG's Avatar
KPG
Jags, here is the distributor map.... http://www.vpracingfuels.com/dist.html
Old Feb 13, 2007 | 11:17 PM
jags911tt's Avatar
Thanks Kev
Old Feb 13, 2007 | 11:23 PM
KPG's Avatar
KPG
Thanks Kev
No prob...you need all the help you can get Just kidding.... Kevin
Old Feb 14, 2007 | 12:00 AM
Dr_jitsu's Avatar
true, but what passes for 104 is 100-101 and 93 is really 89-90. VP 109 is the best gas I have readily available, and for what I need right now 5 gallons per tank does the job. Now in the future, when I upgrade MAF, fuel pump , injectors....
Old Feb 14, 2007 | 12:06 AM
jags911tt's Avatar
I need more than help when your dealing with the mod bug!
