Battery replacement
Old Mar 11, 2007 | 04:00 PM
Gunther's Avatar
Gunther Is a GOD !Gunther Is a GOD !Gunther Is a GOD !Gunther Is a GOD !Gunther Is a GOD !Gunther Is a GOD !Gunther Is a GOD !Gunther Is a GOD !Gunther Is a GOD !Gunther Is a GOD !Gunther Is a GOD !
Battery replacement
My battery is dead and needs to be replaced. Which battery are people having good luck with? My car is a 2002.
Specific make and model number would be puch appreciated.
Old Mar 11, 2007 | 04:16 PM
jimmer23's Avatar
jimmer23 Is a GOD !jimmer23 Is a GOD !jimmer23 Is a GOD !jimmer23 Is a GOD !jimmer23 Is a GOD !jimmer23 Is a GOD !jimmer23 Is a GOD !jimmer23 Is a GOD !jimmer23 Is a GOD !jimmer23 Is a GOD !jimmer23 Is a GOD !
Optima Red Top
Old Mar 12, 2007 | 01:59 AM
JWC's Avatar
JWC
JWC is infamous around these parts
Optima Yellow top for me.
Old Mar 12, 2007 | 08:34 AM
silvershark's Avatar
silvershark is infamous around these parts
Thumbs up
Interstate makes a battery that is 5lbs-8lbs lighter than the Optima.
And it won't lighten you wallet. $78.00 75month warranty
Optima $135.00-$140.00....I was shopping like you, as my
battery died as well...when I found the Interstate.(24.8lbs)
Interstate is a very respected battery co.
Old Mar 12, 2007 | 01:58 PM
Gunther's Avatar
Is either the Interstate or the Optima a direct replacement? I went to the Optima site and they do not list a OEM fit for the car.
Surely someoone has replaced the battery with direct fit
Old Mar 12, 2007 | 02:53 PM
jimmer23's Avatar
Old Mar 12, 2007 | 08:19 PM
IAPorscheDoc's Avatar
IAPorscheDoc has a reputation beyond reputeIAPorscheDoc has a reputation beyond reputeIAPorscheDoc has a reputation beyond reputeIAPorscheDoc has a reputation beyond reputeIAPorscheDoc has a reputation beyond reputeIAPorscheDoc has a reputation beyond reputeIAPorscheDoc has a reputation beyond reputeIAPorscheDoc has a reputation beyond reputeIAPorscheDoc has a reputation beyond reputeIAPorscheDoc has a reputation beyond reputeIAPorscheDoc has a reputation beyond repute
If you want a standard replacement, a group 48 battery is a direct fit, and slightly shorter end to end. It bolts down in the tray like normal. Any auto parts store battery will do, they are all made by the same manufacturer more or less, just relabled. We use interstate the most.
Just don't replace it with a Porsche battery
Old Mar 13, 2007 | 07:02 AM
Gunther's Avatar
Doc,
Thanks for the info. I'm off to see the Interstate man because I would much prefer to avoid the Porsche battery.
Old Mar 13, 2007 | 09:08 AM
Highhats's Avatar
Highhats is a splendid one to beholdHighhats is a splendid one to beholdHighhats is a splendid one to beholdHighhats is a splendid one to beholdHighhats is a splendid one to beholdHighhats is a splendid one to behold
My interstate battery was garbage. Brand new and it didnt work for **** for my porsche. Use the optima. No more old school alarm issues and car starting issues like before. I use the yellow top. Interstate truck has them also. Just bolt it directly to the black plate under the stock battery. IMO
-Suman
0396's Avatar
0396 has a reputation beyond repute0396 has a reputation beyond repute0396 has a reputation beyond repute0396 has a reputation beyond repute0396 has a reputation beyond repute0396 has a reputation beyond repute0396 has a reputation beyond repute0396 has a reputation beyond repute0396 has a reputation beyond repute0396 has a reputation beyond repute0396 has a reputation beyond repute
" Just don't replace it with a Porsche battery
Don't really understand..care to expand on this?
Are they too heavy and or just don't last?
Thank you!
Old Mar 13, 2007 | 10:33 AM
JWC's Avatar
JWC
From what I hear and read the the OEM batteries just don't last. Our P cars drain them at a very good rate and most P car owners don't use the p car as a daily driver. (lots of drain less charging). The Optima batteries are H/D and work like trolling motor batteries; they can discharge and charge many many times and keep on working. Some people opt for a standard Interstate or other and plug into a Battery Tender to keep the battery at full charge. To sum it up: I think you would pay more for the Porsche batteryand IMO get average performance. The standard other group 48's Interstate / Sears are as good and cost less. The Optima cost more but will work better and last longer.
Old Mar 13, 2007 | 10:35 AM
0396's Avatar
JWC,
Thanks for responding.
Old Mar 13, 2007 | 10:37 AM
JWC's Avatar
JWC
You are very welcome!
pwdrhound
Sep 16, 2021 02:27 PM
Jul 29, 2019 11:13 AM
DetomasoGTS74
Nov 11, 2015 09:01 AM
OldBoldPilot
Aug 24, 2015 04:00 PM
DSCOFF
Aug 23, 2015 01:22 PM
