Question on Clutch Pressure Accumulator
Old Mar 14, 2007 | 06:43 PM
MikeR's Avatar
MikeR is infamous around these parts
My clutch pressure accumulator is going bad, clutch pedal is stiff when the car is cold. The dealer, the SA, said this would be fine if I waited until I got some work done later. Not too sure if I trust the SA.
My question- Will not replacing the clutch accumulator cause any other damage? And is there anything else I should have checked when I do get it fixed? The Clutch and transmission are fine.
I have been debating on some mods, and was wondering if I could wait and do it all at the same time.
Old Mar 15, 2007 | 12:56 AM
cjv's Avatar
cjv
Moderator
It won't hurt anything. It will make for a heavier pedal. I took mine off years ago.
Old Mar 15, 2007 | 10:41 AM
MikeR's Avatar
Thank you.
Old Mar 15, 2007 | 04:17 PM
alevine's Avatar
alevine has a spectacular aura aboutalevine has a spectacular aura about
I have the same issue. Any idea on the time and cost to replace the accumulator? How much in parts and labor?
Thanks,
Adam
Old Mar 15, 2007 | 05:09 PM
justinmm2's Avatar
justinmm2 Is a GOD !justinmm2 Is a GOD !justinmm2 Is a GOD !justinmm2 Is a GOD !justinmm2 Is a GOD !justinmm2 Is a GOD !justinmm2 Is a GOD !justinmm2 Is a GOD !justinmm2 Is a GOD !justinmm2 Is a GOD !justinmm2 Is a GOD !
alevine,
I forget the exact cost (can check at home), but I know it was *under* $400.. I think $350?
Justin
Old Mar 15, 2007 | 05:57 PM
alevine's Avatar
Originally Posted by justinmm2
alevine,
Justin
Great. Thanks for your help. Much appreciated. Was the $350 for parts and labor? If so, that's a no brainer. I'll get it fixed ASAP.
Adam
Old Mar 15, 2007 | 06:05 PM
justinmm2's Avatar
Yes, parts and labor. I'm fairly certain $350 was it.
Old Mar 15, 2007 | 07:24 PM
Blue Bayou's Avatar
Blue Bayou is infamous around these parts
Had it removed – no issues.
Old Mar 15, 2007 | 08:02 PM
MikeR's Avatar
One reason I did not have mine changed at the dealer, they quoted me over $1000. Said it was a pain to get to. I thought that was a little steep. I plan on calling around to some local independents to see what they charge.
Old Mar 16, 2007 | 04:24 PM
alevine's Avatar
justinmm2:
Do you have the part numbers needed for the job? I can buy the parts from one of the vendors on the right and have my local shop do the install.
Thanks again,
Adam
Old Mar 16, 2007 | 04:47 PM
justinmm2's Avatar
All,
http://www.renntech.org/forums/index...howtopic=12591
Should be immensely helpful. If you are not a Renntech member, they link to this part (and use the expression "max $300" [P&L]):
http://www.pelicanparts.com/catalog/...Tclutc_pg5.htm
$127
The Pelican page says 996-314-166-00-M270 but please, PLEASE keep in mind the receipt for the work I had done at a dealer is at home. I will not be home until tomorrow, but can check it then for you if you like.
Old Mar 16, 2007 | 04:55 PM
justinmm2's Avatar
Note that the Pelican Part # I gave is listed as "Corteco Brand"
Old Mar 16, 2007 | 04:57 PM
alevine's Avatar
justinmm2:
Awesome info! Thanks for your help. Much appreciated.
Adam
COBB Tuning
Jan 1, 2025 09:02 AM
Jul 29, 2019 11:13 AM
LiquidElephant
Aug 27, 2015 06:17 PM
The Oss
Aug 24, 2015 08:19 PM
