Help with Stabilizer Bar options - 996TT
Old Mar 23, 2007 | 01:54 PM
MGS996TT's Avatar
MGS996TT is a splendid one to beholdMGS996TT is a splendid one to beholdMGS996TT is a splendid one to beholdMGS996TT is a splendid one to beholdMGS996TT is a splendid one to beholdMGS996TT is a splendid one to beholdMGS996TT is a splendid one to beholdMGS996TT is a splendid one to behold
Have recently ordered X73 Suspension package for my 2001 TT. Now looking to order new front & rear stabilizer bars.....firstly, are new bars required? Any recommendations? Cheers
Old Mar 23, 2007 | 02:41 PM
buddyg's Avatar
H & R makes sway bars for front and rear and they do work well.
Old Mar 23, 2007 | 06:54 PM
WOODTSTER's Avatar
+ one to the Good Buddy.
I run rear H&R only and it worked great at the track (middle setting).
MK
Old Mar 23, 2007 | 07:25 PM
oak's Avatar
oak
the stock hollow GT3 sways ain't bad.
Old Mar 24, 2007 | 07:29 AM
MGS996TT's Avatar
What's the difference in size between the 996TT sway bars vs GT3. Measured the rear bar tonight and it's the same as the GT3 spec (20.8mm).
Cheers
MGS
Old Mar 24, 2007 | 01:11 PM
silver's Avatar
silver is a name known to allsilver is a name known to allsilver is a name known to allsilver is a name known to allsilver is a name known to allsilver is a name known to all
GT3 is adjustable and the turbo is not. These adjustments make the gt3 bar much stiffer when adjusted regardless of the diameter. I run the gt3 rear only with stock turbo front and it is fine. If I wanted both I would run the H&R and not fool with new drop links.
Old Mar 24, 2007 | 01:14 PM
oak's Avatar
oak
I've had a couple of the stock dl's fail.
Old Mar 24, 2007 | 07:08 PM
silvershark's Avatar
silvershark is infamous around these parts
Thumbs up
I run the H&R rear only, it noticbly reduces understeer.
I also have F&R carbon strut tower braces.
BlackHorseTurbo
Apr 20, 2016 10:26 PM
