Dip in HP/TQ on my Dyno (X50 w/ GIAC/Evo)
Old Mar 28, 2007 | 08:17 PM
Originally Posted by nash
I remember that on the dyno it hit 1.3 and then dialed back to 1.1 quickly. I will drive it some tonight to test.
so there is ur spike... 1.3 bars and ur dip which is between 1.3 and 1.1 bars.
if u set it right it should just stay 1.2 bars. Ideally u want 1.25 bars steady.
with the upgraded actuators it should drop liek that form 1.3 to 1.1 bars...
thats why u have upgraded actuators... so it keeps the boost where u want it.
Also, what fuel were u running?
2001 996TT 3.6L and stock ECU
9.66
seconds @ 147.76 mph 1/4 mile
click to view
Old Mar 28, 2007 | 08:35 PM
nash's Avatar
nash is infamous around these parts
93 octane, texaco.
Yeah, I think you are right - the drop in boost from 1.3 to 1.1 would explain the dip in the graph. I'll try to replicate it on the street tonight and then see if I can get the actuators adjusted in the next day or two.
Old Mar 28, 2007 | 08:54 PM
nash's Avatar
Just so I know what to look for... should I never see 1.3 on the gauge if it's set correctly? Max 1.2 and holding steady?
Old Mar 28, 2007 | 09:03 PM
LUISGT3's Avatar
You should NOT see 1.3.
Old Mar 28, 2007 | 10:00 PM
Highhats's Avatar
Highhats is a splendid one to beholdHighhats is a splendid one to beholdHighhats is a splendid one to beholdHighhats is a splendid one to beholdHighhats is a splendid one to beholdHighhats is a splendid one to behold
the dyno probably didnt mimic load so the dips wouldnt occur in the street. Just a thought
-SM
Old Mar 28, 2007 | 11:00 PM
ringmaster's Avatar
ringmaster is infamous around these parts
Originally Posted by x50plt
I just changed mine out (wastgates) and they should be set with a pressure tester. very easy to do. low pressure regulator and a good low pressure guage 0-15 or 0-20 psi they must be done on the turbos. at 12 psi they should begun to crack open adjust them evenly.
Can someone please explain the correct procedure for calibrating the EVO actuators? What is the pressure tester you mention?
Old Mar 28, 2007 | 11:08 PM
Turbo Fanatic's Avatar
Pull off the boost hoses, connect a pump, and start pumping at 12 PSI you should see the rod start to move. If it doesn't, loosen it until it does.
Rinse and repeat.
Old Mar 28, 2007 | 11:18 PM
Zippy's Avatar
You will know TB shut down on the street when it happens. I had that situation when my car was a GT640. Top of 4th @ 1.3+ bar and WHAM! The braking effect of the TB shut down throws you hard against the chest strap of your seat belt. Hit it 2-3 times and it will go into limp mode. I believe Mark is correct - although I believe you should dail your nuts back more than 1/2 turn. I'd loosen your nuts 1.5 - 2.0 full turns and test there. Move up in 1/2 turn increments to bring back the boost. Good Luck.
Old Mar 29, 2007 | 10:15 AM
wross996TT's Avatar
IMO you should hold 1.2 and see 1.3 spikes...so you are at about 1.25 as Mark points out.
Old Apr 3, 2007 | 08:22 PM
Pierre996TT's Avatar
Pierre996TT has a spectacular aura aboutPierre996TT has a spectacular aura aboutPierre996TT has a spectacular aura about
Question
Rinse and repeat.
could you please develop this a little more...I just got the EVO WG and I have stage 4....which will be the right measure? PSI?..
Emre@Esmotor
Oct 19, 2015 12:06 PM
ModBargains.com
996 Turbo Vendor Classifieds
Oct 1, 2015 11:48 AM
