Hoosier R6 - size, tire pressure for track
Old May 1, 2007 | 01:58 PM
Whirls's Avatar
Whirls is infamous around these partsWhirls is infamous around these parts
Please let me know what size R6's you guys are going with (996TT). Front choices are 225/40/18, 245/35/18 or 245/40/18. I was going to go with the 245's in front, and considering I ususally go with 235/40/18's, I thought it may be better to get the 245/35's to help prevent rubbing... Please let me know. Also, for those of you that use Hoosiers on the track, what tire pressure do you start with cold (and where do you want them to be hot)? Any help would be appreciated! Thanks!!
Old May 1, 2007 | 02:31 PM
Joe Weinstein's Avatar
You want 46820 P245/35ZR18, and 46840 P285/30ZR18
The diameters are the closest, and the right for stock
wheel widths. You'd want low 40's psi hot.
Old May 1, 2007 | 02:42 PM
Whirls's Avatar
Thanks! But, my wheels are 8.5" in front and 11.5" in the rear (I have the RUF 3 piece wheels and the HRE C21's) I should have mentioned that in the initial post. Still think 285's, or should I get bigger. I usually run the 235/40/18 and 315/30/18 MPSC's)....
Old May 1, 2007 | 02:47 PM
ccayer's Avatar
ccayer is infamous around these parts
I run 245/35R18 up front and my car is low. No issues with rubbing. They are on 18x8.5 44ET wheels. For the rear I run P315/30R18 on 18x11.5 ET44.
No issues with rubbing at all.
Great setup! I was able to keep temps between 40 and 44 and they were WAY sticky!!!!!!!
Old May 1, 2007 | 02:50 PM
Whirls's Avatar
Thanks for the info. What tire pressure did you start with to end up with 40 and 44 hot??
Old May 1, 2007 | 02:51 PM
Then you might want:
46825 P245/40ZR18
and
46846 P315/30ZR18
Old May 1, 2007 | 02:55 PM
Whirls's Avatar
46825 P245/40ZR18
and
46846 P315/30ZR18
Thanks!!!!!!!
Old May 1, 2007 | 06:49 PM
ccayer's Avatar
LF 32, RF 34, LR34, RR 35
Our track (PIR) beats up the left sides in general.
Old May 1, 2007 | 07:00 PM
Whirls's Avatar
Good info - I will adjust for our track accordingly. Thanks alot for the help!
Old May 1, 2007 | 09:39 PM
WOODTSTER's Avatar
245/295
over 40 hot is very hot.
start in 30's and keep in 30's (30/32 == 33/35 or 34/36)
MK
Old May 1, 2007 | 11:51 PM
ccayer's Avatar
Woodtster why do you say that? We might have conflicting info. My tire engineer recommeded 40 to 45 for the hoosiers on my car. I know the subie guys try to get 52 in theirs.
Originally Posted by WOODTSTER
245/295
MK
Old Feb 27, 2008 | 10:35 PM
contigo's Avatar
contigo has a brilliant futurecontigo has a brilliant futurecontigo has a brilliant futurecontigo has a brilliant futurecontigo has a brilliant futurecontigo has a brilliant futurecontigo has a brilliant futurecontigo has a brilliant futurecontigo has a brilliant futurecontigo has a brilliant futurecontigo has a brilliant future
I have 19 inch and doing 40/44 R6 tires
Old Mar 1, 2008 | 06:42 AM
eclou's Avatar
eclou Is a GOD !eclou Is a GOD !eclou Is a GOD !eclou Is a GOD !eclou Is a GOD !eclou Is a GOD !eclou Is a GOD !eclou Is a GOD !eclou Is a GOD !eclou Is a GOD !eclou Is a GOD !
Hoosier recommends the optimal hot pressure as being around 40-44 on the R6. Past compounds were different. I get the best stick at those pressures and start at 32/34 cold on my TT and then check temps with a pyrometer and bleed accordingly
Old Mar 1, 2008 | 06:59 AM
contigo's Avatar
Which TT? 2007? if so which dimension tire are you using since they dont have the exact dimension as your OEM?
Old Mar 1, 2008 | 07:05 AM
eclou's Avatar
I run 245/35/18 front and 305/30/18 rear Hoosiers on my 07 997TT. The 305/30/18 is actually a VRL compound - Viper Racing League - which is almost identical to an R6. The tire heights are shorter but the ratio of front:rear is within 1% of the stock tire sizes and the diff and electronics are unphased.
