First drag pass in Protomotive GT2
Old May 9, 2007 | 06:06 PM
  #31
KPG's Avatar
KPG
KPG Is a GOD !KPG Is a GOD !KPG Is a GOD !KPG Is a GOD !KPG Is a GOD !KPG Is a GOD !KPG Is a GOD !KPG Is a GOD !KPG Is a GOD !KPG Is a GOD !KPG Is a GOD !
Jaime, what boost level and fuel were you running? The reason I ask is that we know Norwalk is a fast track, but compared to some other Proto cars I would have thought your trap would be higher. For example, you put 715rwhp down on TK's dyno and trapped 135mph, yet Scott in his old setup put down 565 on a DD and trapped 136 with a heavier car. Even given the differences in day,driver and track I dont understand why he would still be faster with more weight and 150 RWHP less...Even considering your launch, most trap speeds arent that affected by poor launch. Just curious since it is generally agreed that trap speed is king around here...Take care, Kevin
Old May 9, 2007 | 06:08 PM
  #32
iLLM3's Avatar
This also interests me, would like some opinions from both parties
Old May 9, 2007 | 06:20 PM
  #33
John D's Avatar
John D is a splendid one to beholdJohn D is a splendid one to beholdJohn D is a splendid one to beholdJohn D is a splendid one to beholdJohn D is a splendid one to beholdJohn D is a splendid one to beholdJohn D is a splendid one to behold
I thought the same thing...
Old May 9, 2007 | 07:38 PM
  #34
Divexxtreme's Avatar
He probably let out early. Jamie's car went quicker than DMK's car did in 60-130 (5.93 vs 6.15) It's easily capable of trapping 138-139 MPH.
Old May 9, 2007 | 07:52 PM
  #35
Alex's Avatar
Alex has a brilliant futureAlex has a brilliant futureAlex has a brilliant futureAlex has a brilliant futureAlex has a brilliant futureAlex has a brilliant futureAlex has a brilliant futureAlex has a brilliant futureAlex has a brilliant futureAlex has a brilliant futureAlex has a brilliant future
No offense to Jaime, but 'granny-shifting' + soft launch = slower traps.
Old May 9, 2007 | 07:57 PM
  #36
OhioGT2's Avatar
OhioGT2 Is a GOD !OhioGT2 Is a GOD !OhioGT2 Is a GOD !OhioGT2 Is a GOD !OhioGT2 Is a GOD !OhioGT2 Is a GOD !OhioGT2 Is a GOD !OhioGT2 Is a GOD !OhioGT2 Is a GOD !OhioGT2 Is a GOD !OhioGT2 Is a GOD !
103/C12 mix at 1.3 bar peaking 1.4 after 6500. Unless Scott ran on the same track, same day, (even better yet, use the same driver it's impossible to compare times/traps. I granny shifted the whole way down, shifting right at 7k through all gears. Picking up some mph shouldn't be hard with some seat time. I was more curious as to what my trap would be driving it like I do on the street everyday , so I wouldn't use this slip as representative of what it could do if someone was trying to get a time out of it....
FYI, I've dyno'd approx 670 to the tire on two completely different dynojets at 1.4 bar with less than optimal fan set-ups, both in 4th gear. Todd dyno'd my car in 5th gear at 1.5 bar, in 40 degree temps, with the air filters off, and with a good fan set-up. So factoring in those variables, his numbers seem to be fairly accurate with what I'm seeing independently.
Old May 9, 2007 | 09:07 PM
  #37
I really do not think it is a fair comparisson.
First of all, Scott was on DR tires and he went for it. Jamie was on street tires. A simple tire spin will loose u anywhere from 3 to 7 MPH... Jamie was probably on 19"s- if so it even makes things worse.
just my opinion.
mark
2001 996TT 3.6L and stock ECU
9.66
seconds @ 147.76 mph 1/4 mile
click to view
Old May 9, 2007 | 09:12 PM
  #38
OhioGT2's Avatar
Actually I was running my 18" C21's with BFG DR's. I wheel hop too much in 1st on my 19's
Old May 9, 2007 | 09:20 PM
  #39
Even so, it still hard to compare.... for example we ran 142 on lower boost one day and 145mph on higher boost. On the next try it was the other way around... we ran 145 mph on lower boost... WTF???
mark
9.66
click to view
Old May 9, 2007 | 09:30 PM
  #40
OhioGT2's Avatar
I agree. The only way to compare cars is to have the same driver run them on the same day at the same track. But if that ever happened, what the hell would we have to talk about all day?
Old May 9, 2007 | 09:52 PM
  #41
I agree...
9.66
click to view
Old May 10, 2007 | 04:09 AM
  #42
I think that might be the key difference right there. I speed-shifted at redline (7,400) in each gear.
Regardless, my car certainly could not have ran 5.93 60-130 at that time like you did...so I know for fact that your car is much faster than what I had back then.
LTCJMRamos
Merchandise For Sale / Wanted
Sep 22, 2015 11:16 AM
BLKMGK
Sep 19, 2015 03:51 PM
MrJoshua
Sep 6, 2015 02:06 PM
John@SpeedTech
Sep 4, 2015 07:23 AM
