Tire milage
Old May 11, 2007 | 09:38 PM
stingray's Avatar
stingray is infamous around these parts
Tire milage
I am running (or was) ContiSportContactâ„¢ 2 Vmax 315/25/19 and got less than 5,000 miles. Is anybody getting anything NEAR decent milage? What brands???
Old May 11, 2007 | 10:22 PM
ezmoney888's Avatar
ezmoney888 has a reputation beyond reputeezmoney888 has a reputation beyond reputeezmoney888 has a reputation beyond reputeezmoney888 has a reputation beyond reputeezmoney888 has a reputation beyond reputeezmoney888 has a reputation beyond reputeezmoney888 has a reputation beyond reputeezmoney888 has a reputation beyond reputeezmoney888 has a reputation beyond reputeezmoney888 has a reputation beyond reputeezmoney888 has a reputation beyond repute
My PS2's have almost 8k in the rear with a lot to go. My alignment is not too aggressive in the rear becuase I do a lot of highway miles and that helps a lot.
Old May 11, 2007 | 10:32 PM
stingray's Avatar
What size are your tires? Mine's been lowered and I've had I've had adjustable links put on the rear so I can get the camber out. Mine wore perfect across, they just wore out with less than 5,000 miles on them. Zero time at the track and resonably tame street use.
Old May 11, 2007 | 10:43 PM
ezmoney888's Avatar
same as yours. when i bought my car it had almost new conti tires that i went through in 5k miles as well. When I got the michelins I had the car raised about 1/4 inch and adjusted camber. Conti's are cheaper tires but I've learned you get what you pay for. Also, I like the PS2 becuase they are quieter (like it matters with the exhaust noise) and doesn't harden up like the conti's.
Old May 12, 2007 | 12:39 AM
HIGHcard's Avatar
HIGHcard has much to be proud ofHIGHcard has much to be proud ofHIGHcard has much to be proud ofHIGHcard has much to be proud ofHIGHcard has much to be proud ofHIGHcard has much to be proud ofHIGHcard has much to be proud ofHIGHcard has much to be proud ofHIGHcard has much to be proud ofHIGHcard has much to be proud of
ME TOO!? took my car to the tire shop yesterday all excited because i was going to rotate my tires i ended up needing brand new tires all together since my contis were out for the count friggin contis man...anyone else? my camber was pretty dang aggressive though
Old May 12, 2007 | 12:41 AM
SallyMobile's Avatar
SallyMobile is a jewel in the roughSallyMobile is a jewel in the roughSallyMobile is a jewel in the rough
What toe settings are you running?
Old May 12, 2007 | 08:09 AM
andyk79's Avatar
andyk79 is infamous around these parts
I got PS2's on my car and got roughly 9k with aggressive driving. I also have a very aggressive camber as well. I believe if you have stock camber set up you should be able to get atleast 15k. Thats what I was getting prior to my set up.
Old May 12, 2007 | 02:53 PM
John D's Avatar
John D is a splendid one to beholdJohn D is a splendid one to beholdJohn D is a splendid one to beholdJohn D is a splendid one to beholdJohn D is a splendid one to beholdJohn D is a splendid one to beholdJohn D is a splendid one to behold
I get 5-6 K on rears and they are gone. I do three rears to one front, then change the fronts, as they are pretty worn at that point.
danyoP4S
Sep 30, 2021 05:06 AM
WheelB
991 Turbo Vendor Classifieds
Jul 23, 2018 09:37 PM
oo7
Sep 10, 2015 08:08 AM
WheelB
Sep 3, 2015 10:26 AM
gabe325
911
Sep 2, 2015 08:10 PM
