Defective Tires or Car??
Old May 12, 2007 | 09:41 PM
whorespower's Avatar
whorespower is infamous around these parts
Just put new shoes on my car - P Zero's. 5k miles on them. Left rear has about 70% tread. Right rear is worn down to around 25%...Front are fine. I thought about camber but wouldn't both be worn? Could the tire be defective? Thanks for any advice.
Old May 12, 2007 | 10:18 PM
GT3 Chuck's Avatar
Administrator
tire could be defective but most likely alignment on right rear..camber or toe (adjustments left and right are independent) you didn't say if the tire was worn on inside, outside or evenly, cupped, crowned...typically P cars wear inside edge on rear if too much camber
Old May 12, 2007 | 10:26 PM
ard's Avatar
ard
Remember- there are 4 tires on the ground and the axles are not independent.... The other 3 tires can influence the wear on a fourth.
You probably have too much toe on the rear tires. Not sure on this car, but I prefer keeping it as close to zero as the factory spec allows. Dealerships just check to see if it is 'in the range'.. you want to spec it WITHIN the range.
Old May 12, 2007 | 11:23 PM
ezmoney888's Avatar
ezmoney888 has a reputation beyond reputeezmoney888 has a reputation beyond reputeezmoney888 has a reputation beyond reputeezmoney888 has a reputation beyond reputeezmoney888 has a reputation beyond reputeezmoney888 has a reputation beyond reputeezmoney888 has a reputation beyond reputeezmoney888 has a reputation beyond reputeezmoney888 has a reputation beyond reputeezmoney888 has a reputation beyond reputeezmoney888 has a reputation beyond repute
+1 for Alignment.
PorscheEnthusiast
Nov 13, 2015 02:23 PM
COBB Tuning
Nov 9, 2015 08:02 PM
The_Ruski_Driver
Oct 25, 2015 08:40 PM
Fallbangskid
Aug 21, 2015 02:35 PM
albert@velosdesignwerks
Lamborghini
Aug 20, 2015 10:15 PM
