What boost for stage 4 k24/26
Old May 19, 2007 | 01:34 AM
Triss's Avatar
Triss is infamous around these parts
I am wondering what boost the turbos charge in stage 4 kits with k24/26 turbos? For example fvd´s stage 4 kit.
For gt2 that is...
Old May 19, 2007 | 06:27 AM
WOODTSTER's Avatar
Are you asking when they hit full boost or what is the max boost they will
run before they run out of efficiency??
mK
Old May 19, 2007 | 10:28 AM
RSS's Avatar
RSS
RSS is a name known to allRSS is a name known to allRSS is a name known to allRSS is a name known to allRSS is a name known to allRSS is a name known to all
My 24/26 spike at 1.3 bar. But this is from a 993TT.
Old May 19, 2007 | 04:19 PM
the st up will hit 1.2 bars then drop off to 1.1 bars.... u can upgrade the WGs and if installed properly they can aloow 1.3 bars... Throttle body shutdown will occur at 1.3 bars so its a fine line between max boost and TB shutdown...
markski
2001 996TT 3.6L and stock ECU
9.66
seconds @ 147.76 mph 1/4 mile
click to view
Old May 19, 2007 | 09:11 PM
AMG ETR's Avatar
1.2bar is about right for FVD stage 4 cars....
Old May 20, 2007 | 12:48 AM
jalmood's Avatar
jalmood has a spectacular aura aboutjalmood has a spectacular aura aboutjalmood has a spectacular aura about
My car is a stage IV fvd except for the air intake plenum and Max. boost i saw is 1.2 bar.
Old May 20, 2007 | 02:35 AM
Turbo Fanatic's Avatar
I run 1.2 BAR on stock K24s. In the higher gears you get 1.3 showing for a split second before the wastegates open up a bit and bring it down to a solid 1.2.
Fadi
Aug 17, 2018 05:16 PM
maroli
Sep 15, 2015 07:07 PM
jyupitt1
Sep 10, 2015 03:56 AM
