Can you
Old May 27, 2007 | 12:24 PM
mr2guysingh's Avatar
mr2guysingh is a splendid one to beholdmr2guysingh is a splendid one to beholdmr2guysingh is a splendid one to beholdmr2guysingh is a splendid one to beholdmr2guysingh is a splendid one to beholdmr2guysingh is a splendid one to behold
Can you
Get an extended warranty for a used 996TT if you weren't the original owner?
Old May 27, 2007 | 12:44 PM
OCTurbo's Avatar
OCTurbo is infamous around these parts
yes, but the car still has to be under factory warranty for most aftermarket warranty companies. Most people go with the easy care warranty (divison of Ford), which can be purchased at many porsche dealerships.
Old May 27, 2007 | 12:51 PM
So if it has a CPO warranty, you can get a Porsche extended warranty on the car? Or it has to be under the factory warranty?
Old May 27, 2007 | 12:56 PM
OCTurbo's Avatar
Do you want to extend the warranty beyond your cpo warranty? If so, you'll have to contact the dealership who sells the aftermarket warranties to see if they will sell you a warranty. In CA i think it has to be under the original factory warranty.
Old May 27, 2007 | 01:00 PM
I want an extended or CPO warranty for 4 years, because I know these car's are expensive to repair. I'm try find a car with a factory or CPO warrany, and if I can extend it, it would be great.
Old May 27, 2007 | 01:06 PM
OCTurbo's Avatar
The cpo warranty gives you an extra 2 yrs after the end of the factory warranty. So only if you get a 2005 turbo will you get 4 years of warranty (factory warranty till 2009 plus 2 more yrs to 2011). If you get an older car, you'll have to go with an aftermarket warranty, which can be longer coverage if you choose (i got a 6yr/75kmi).
Old May 27, 2007 | 01:09 PM
Well, I'm looking at 2002-2003 996TT.
With aftermarket warranty's, do you have to pay the bill, then send the bill to the company and they pay you back, or they pay the Porsche dealership?
Old May 27, 2007 | 01:13 PM
OCTurbo's Avatar
Once the repair is approaved, the warranty company pays the dealership directly. However, there is usually a deductible of $100-$200.
Old May 27, 2007 | 01:14 PM
Ouch.
So if I find a car with a CPO warranty, I can extend it, correct?
Old May 27, 2007 | 01:18 PM
OCTurbo's Avatar
I don't think you can with most warranty companies- most require that the car is under the original factory warranty. However, you should call your porsche dealership to find out the specifics of the aftermarket warranty.
Old May 27, 2007 | 01:21 PM
Oh, ok. Sounds good.
These car's dont have many major issues, just the 2nd gear pop-out?
Old May 27, 2007 | 01:23 PM
OCTurbo's Avatar
These cars are very reliable and i think the second gear pop out issue is probably overstated. Good luck with your search.
Old May 28, 2007 | 12:59 PM
rcalcaide's Avatar
rcalcaide has much to be proud ofrcalcaide has much to be proud ofrcalcaide has much to be proud ofrcalcaide has much to be proud ofrcalcaide has much to be proud ofrcalcaide has much to be proud ofrcalcaide has much to be proud ofrcalcaide has much to be proud ofrcalcaide has much to be proud ofrcalcaide has much to be proud of
I went with Easycare on my 02 turbo. it was out of the factory warranty, and it had only 5k miles on it. I wanted to make sure I got a good extended warranty on the car. Easycare had the most favorable reviews. Plus my independant Porsche garage accepted the warranty. no more stealership work for my turbo.
Old May 28, 2007 | 02:03 PM
ard's Avatar
ard
I too am evaluating extending a warranty.
At first glance the CPO warranty, backed by Porsche, seems best....
BUT- I've seen two draw backs:
1. You need to use a dealer.
2. The dealer has a financial 'conflict' in that they (through PCNA) are paying the bill- they can maniulate the data to deny a claim in a worst case, or can simply do a very thorough investigation and know what to look for to deny claims. (Over-rev data, etc)
On the other side of the equation, the CPO extended warranty is backed by Porsche...
A
Old May 28, 2007 | 02:22 PM
How much did you pay, and for how many years/miles? I read online, and they would pay the Porsche dealer directly
