Eclipse Radio Security Issue
Old May 29, 2007 | 05:48 AM
Arnie's Avatar
Arnie is infamous around these parts
I have a problem with my new used car an 89 turbo which I got to join my 2003 turbo. So it needed a new battery (89) when the battery was reconnected the radio lights up but will not play. Read the manual seems you need to insert a "key CD". Well I am the 3rd owner and I have the radio manual. The guy I bought it from new nothing about it since he never disconnected the battery he did not have a problem. Is there a way to get the radio working without having to send it back to the factory as instructed in the manual? Without knowing which CD was used I am stuck All help appreciated thanks
Arnie
Old May 29, 2007 | 09:14 AM
imola's Avatar
imola is infamous around these parts
Had an eclipse unit years ago and it happend to me. without the orginal cd that was used as the key, you'll have to send it back to the factory.
giving how cheap the head units are these days, might as well consider change the head instead.
Old May 29, 2007 | 10:56 AM
Simba's Avatar
Simba has much to be proud ofSimba has much to be proud ofSimba has much to be proud ofSimba has much to be proud ofSimba has much to be proud ofSimba has much to be proud ofSimba has much to be proud ofSimba has much to be proud ofSimba has much to be proud of
Call Eclipse. They have a proceedure to unlock the unit if you've exhausted the cd key tries.
You'll want the serial number of the unit handy.
Old May 29, 2007 | 12:26 PM
Seattle996's Avatar
Seattle996 has a reputation beyond reputeSeattle996 has a reputation beyond reputeSeattle996 has a reputation beyond reputeSeattle996 has a reputation beyond reputeSeattle996 has a reputation beyond reputeSeattle996 has a reputation beyond reputeSeattle996 has a reputation beyond reputeSeattle996 has a reputation beyond reputeSeattle996 has a reputation beyond reputeSeattle996 has a reputation beyond reputeSeattle996 has a reputation beyond repute
Buddy, I encountered the same thing when installing a cd player that i purchased from a friend. Couldn't get the stupid thing to work, even w/ the CD he told me to buy. I ended up calling Eclipse, and if I remember correctly, I had to fax them a copy of my drivers license and the serial code off the player. Anyways, they gave me an unlock code and I was good to go.
Bojan
PV=nRT.
Sep 9, 2022 06:06 PM
Paintballzen
Oct 10, 2020 12:22 PM
Rguy
Apr 12, 2020 11:11 PM
Rockinc1
Sep 30, 2015 06:44 PM
