adjusting wastegates
Old Jun 4, 2007 | 12:30 PM
cpu77's Avatar
cpu77 is infamous around these parts
Originally Posted by drewTT
bingo. thats exactly how i feel about it now.
looks like the evos are the solution....
I have upgraded Waste Gates. I see no difference in this unless mine just needs adjusted. Does adjusting them cure this?
Old Jun 4, 2007 | 12:42 PM
kayman's Avatar
kayman is infamous around these parts
when I talked to evoms, they told me that their wastegates need to be adjusted based on the car's setup.
Old Jun 4, 2007 | 12:45 PM
wross996TT's Avatar
Definately somethng wrong..you should see a significant improvement in mid-range torque and of course hold 1.2 bar.
Old Jun 4, 2007 | 02:49 PM
Pierre996TT's Avatar
Pierre996TT has a spectacular aura aboutPierre996TT has a spectacular aura aboutPierre996TT has a spectacular aura about
+ my car hits 1.2 bar 500 rpms sooner.
Old Jul 4, 2007 | 01:57 PM
Billystang's Avatar
Billystang is infamous around these parts
so why the factory k24s wastegates cant work?
i thought they make them adjustable to ingrease the boost.
i just put the k24s on and show up to 1.2 some times without adjust the wastegates.
Old Jul 4, 2007 | 09:39 PM
wross996TT's Avatar
Stock springs release boost (pressure) before they need to...over safe. Thus not very efficient in using power...get the upgraded springs!
Old Jul 5, 2007 | 12:05 AM
DERBOOST's Avatar
DERBOOST is a glorious beacon of lightDERBOOST is a glorious beacon of lightDERBOOST is a glorious beacon of lightDERBOOST is a glorious beacon of lightDERBOOST is a glorious beacon of light
just FYI before I changed to the evo WG I checked my stock k24 wg. In the stock setting the wg started to crack open at 7 psi (.5 bar) with the evo the movement starts at 12 psi..
Old Jul 5, 2007 | 11:17 PM
Turbo Fanatic's Avatar
Just read my sig. You NEED wastegate springs with K24s.
Jeanmarcboilard
Sep 22, 2015 05:03 PM
johnny.dangerous
Sep 14, 2015 02:19 AM
