Is it normal for the rear tires to ride on the inner tread
Old Apr 5, 2004 | 05:41 PM
Mark M's Avatar
Mark M is infamous around these parts
for factory stock alignment specs? It appears that my recently aligned Turbo has the rears angled more than the fronts. They appear to be leaning more towards the inside tread. If I won't be tracking the car, wouldn't it be better to straighten them out?
Old Apr 5, 2004 | 06:14 PM
Gary (Fl)'s Avatar
The Newest "Bling King"
Gary (Fl) is infamous around these parts
I have a similar question... I had my wheels changed today and had new rubber put on. I noticed that on my old wheels that the rears were worn to the bars on the inside of the tires and the outsides still had a little rubber left. Is this common with ROW shocks and springs or stock suspension set to the appropriate alignment specs for each? The fronts were worn pretty even...
Old Apr 5, 2004 | 07:48 PM
maxiter's Avatar
maxiter is infamous around these parts
Camber (the degree of angle from vertical) you see is normal, at least in the regard that it should be more pronounced in the rear.
I don't have specs handy for 996T, but for the 993 Turbo, the front spec is -0 degrees 30 minutes and the rear -1 degree 25 minutes. So in the rear, the angle is about 3 times as much as the front.
This will lead to uneven wear on the inside of the tread, especially on the rear, but that camber helps keep the back end planted solid in turns.
I'm no suspension guru, so I can't offer much more detail.
Old Apr 5, 2004 | 08:11 PM
Zippy's Avatar
I intentionally had this done on the rears when I had the ROW suspension installed. I was getting major wear on the outer 1/3 do to AutoX & Track Days. I was thinking this would even the wear and provide more rear stick in the corners. I haven't tested the theory yet (car just came out 3 days ago and straight into the shop for an attitude adjustment) but am anticipating the set-up may promote a bit of UNDERstreer. If so, the front will have to be adjusted with a little - camber also.
If you just drive in straight lines, this set-up is probably not for you or you need to do a little more track time
Mike
Old Apr 5, 2004 | 08:17 PM
Turbo Racer's Avatar
Turbo Racer is infamous around these parts
my experience is that the car has a negative camber setup. For one to use the tire tread uniformly from outer to inner, the car must experience fairly aggressive driving. On the continental sport contacts, on either side after the tread ends, there is a circle of round divits (looks kinda like a design). What they are there for is to show a driver how much s/he is using with the current suspension. So, if you have scuffed the tire evenly from side to side near the round divits, you are using your car likely with very aggressive turning, cornering. if the outer half of the tire, assuming a correct setup, is not worn enough then it may be better to have the suspension set on a less aggressive setting for more even wear. hope this makes sense
Old Apr 6, 2004 | 04:28 AM
Mark M's Avatar
Thanks for all the information you all provided. Very helpful
Old Apr 6, 2004 | 10:22 AM
eride996's Avatar
eride996 is infamous around these parts
you got to have camber in the rear and fronts if you want your car to hook up on the corners. i intentionally added a little more camber to the rears 1.5 deg. that is why it is important to rotate your tires every 3500 miles. to even out the wear. i think the average tire lasts about 10,000 miles. you will go through 2.5 sets or rear tires for every front tire change.
Old Apr 6, 2004 | 10:32 AM
Mark M's Avatar
Originally posted by Ruiner
According to my alignment shop, this is the factory spec range for the rear tires:
rear tire camber: -0.9 to -1.4 deg
At 12,343 miles on the stock suspension mine was:
Left initial: -1.5 deg ... final was -1.1 deg
Right initial: -1.8 deg (yikes) ... final was -1.2 deg
I was showing serious wear on the inside parts of the tread.
Good info Ruiner, I'll keep these numbers on file.
eride996: I had a strong feeling that you have to "pay to play" when it comes to this or any other car of this caliber.$$$$$$
oufan2929
Nov 8, 2015 08:26 PM
L.A.P.
Oct 19, 2015 10:01 PM
JayJayJohn
Sep 17, 2015 05:09 PM
L.A.P.
Aug 23, 2015 11:48 PM
Sterlingc1975
Aug 22, 2015 02:30 PM
