Wheel question... Techart and turbo twists...
Old Jun 15, 2007 | 10:42 AM
str8blst's Avatar
str8blst Is a GOD !str8blst Is a GOD !str8blst Is a GOD !str8blst Is a GOD !str8blst Is a GOD !str8blst Is a GOD !str8blst Is a GOD !str8blst Is a GOD !str8blst Is a GOD !str8blst Is a GOD !str8blst Is a GOD !
Hey Guys,
I recently purchase a set of used Twists from Oak (thanks Oak!) and was wondering if I need to use different bolts to mount them up. Currently I have Techart 19's with what looks to be a 10mm spacer in the rear and no spacer in the front.
Question: Can I reuse the same bolts and spacers for my twists?
I have a track event coming up at the end of the month and want to make sure I have the nessecary hardware for my wheels by then.
Thanks in advance!
Old Jun 15, 2007 | 11:38 AM
GreggT's Avatar
GreggT is a splendid one to beholdGreggT is a splendid one to beholdGreggT is a splendid one to beholdGreggT is a splendid one to beholdGreggT is a splendid one to beholdGreggT is a splendid one to beholdGreggT is a splendid one to behold
Some space out OE hollows as much as 14mm all around.........so 10 in the back would be 'OK' & give you an offset of 35.
No spacer in front would be wimpy (just my opin).
I don't know what Techart bolts look like....but OE bolts are 45mm.
Old Jun 15, 2007 | 11:49 AM
20C4S's Avatar
do the rear bolts look different than the front? Techart wheel uses the same bolt as stock but if u have 10mm spacer then the bolts should be longer. u don't need to use spacer for the twists if they're just for track event.
Old Jun 15, 2007 | 12:01 PM
GreggT's Avatar
If you do use spacers for track events......they will look like this
3WDistributing
31
Oct 27, 2017 01:26 PM
Aug 21, 2015 06:34 AM
PelicanParts.com
930 Turbo Vendor Classifieds
Aug 18, 2015 04:01 PM
PelicanParts.com
GT3/GT2/GT Vendor Classifieds
Aug 18, 2015 03:42 PM
