How much boost can you get away with?
Old Jun 30, 2007 | 01:53 AM
jalmood's Avatar
jalmood has a spectacular aura aboutjalmood has a spectacular aura aboutjalmood has a spectacular aura about
How much boost can i get away with, without damaging my engine, i have a stage IV FVD 575 HP and currently i'm seeing 1.2 Bar.
will it be safe if i can increase up to 1.3 or 1.4, my engine's internal parts are stock, i have only bolt on mods.
advice please
Old Jun 30, 2007 | 06:44 AM
Origyns 973's Avatar
Origyns 973 is a splendid one to beholdOrigyns 973 is a splendid one to beholdOrigyns 973 is a splendid one to beholdOrigyns 973 is a splendid one to beholdOrigyns 973 is a splendid one to beholdOrigyns 973 is a splendid one to beholdOrigyns 973 is a splendid one to behold
advice please
First and foremost what type of fuel are you running. And which turbo's does the FVD Stage 4 package utilize?
Old Jun 30, 2007 | 07:36 AM
WOODTSTER's Avatar
Octane and fueling (air/fuel mixture) are the biggest part of your question.
You dont just "turn up the boost" unless you want to join DMKaboom and the
gang...
MK
Old Jun 30, 2007 | 07:41 AM
jalmood's Avatar
Running 93 octane, and K24/K26 Turbos.
Old Jun 30, 2007 | 08:27 AM
WOODTSTER's Avatar
On 93 you are at max boost (1.2, 1.1 would be safer) regardless of fueling system
You have a nice system, run it as it is designed or Change it entirely.
Good luck!
MK
Old Jun 30, 2007 | 08:39 AM
wross996TT's Avatar
To some extent, there are safety systems built-in to protect from over boost...DVs, wastegates and ultimately the ECU. If you are in an over-boost situation, your Throttle body will shut down and car will go limp to protect it (I think around 1.35). Also need to recognize that you start going beyond "useful" boost when the turbos are maxed out (e.g., 1.1 on 16K). 1.2 sounds about right.
Old Jun 30, 2007 | 11:54 AM
DERBOOST's Avatar
DERBOOST is a glorious beacon of lightDERBOOST is a glorious beacon of lightDERBOOST is a glorious beacon of lightDERBOOST is a glorious beacon of lightDERBOOST is a glorious beacon of light
I run 1.2-1.3 with no issues at all. (k24's)
Old Jun 30, 2007 | 03:36 PM
jalmood's Avatar
so you guys think its safe to kick it up to 1.3 bar? at what boost level does the throttle body shut down, will it allow me to go up to 1.3 bar?
Old Jun 30, 2007 | 03:39 PM
jalmood's Avatar
well even if it was safe to go up to 1.3 bar, how do i do it, is it by adjusting the wastegate? or is there any other way?
Old Jun 30, 2007 | 03:50 PM
I had the saem fvd set up as u did.
I turned up the WGs.... and even used boost controllers.... but u dont need it.
Im not sure ur stock WGs will hold 1.3 bars sustained. do a search as to how to do it. its online here... for someone to expalin it in detail will take some time. warning , if u screw up the adjustement u may create an unbalanced boost setting due to the two WGS.... so one may boost more then the other... be very careful ....
2001 996TT 3.6L and stock ECU
9.66
seconds @ 147.76 mph 1/4 mile
click to view
Old Jun 30, 2007 | 03:51 PM
wross996TT's Avatar
Does the stage IV use the stock waste gates? If so you need to upgrade them, if not then you could tighten them bit, but as I already said...1.2 is great!
Old Jun 30, 2007 | 03:58 PM
If he gets them upgraded then he will have nightmares installing and more importantly adjusting them so they dont hit the magical 1.3 bars and shut down the TB. I have seen many guys upgrade the WGs- liek I did b4... and ended up frustrated becasue I had a hard time setting it up so on colder days they dont casue the car to go into limp mode...
the best solution is a boost controller with upgraded springs so that way can controll the WGs from the inside of u car... but thats a whole different animal ... and I do not recommend just anyone trying,....
9.66
click to view
Old Jun 30, 2007 | 04:09 PM
jalmood's Avatar
Markski and wross996TT thank you guys for the advice, and i think as you guys said 1.2 bar is great and i think its more than enough for the time being
Old Jun 30, 2007 | 04:15 PM
jalmood's Avatar
thanks for your advice i will definitly stay with 1.2 bar
Old Jul 2, 2007 | 03:28 PM
McBurn4ever's Avatar
..never gets enough..
McBurn4ever is infamous around these partsMcBurn4ever is infamous around these parts
To all of you with FVD-upgrades:
How does your car compare with other tuned 996tt's?
Have you had your cars on dyno?
I have a stage III FVD 540 HP, with K24/24, and I'm wondering if my boost is allright..
Most of the time I see max boost att 1.0, sometimes at 1.1.
Other than that my car runs beautiful and smooth with no strange sounds or anything.
Thanks!
