Installing bigger injectors
Old Jul 4, 2007 | 12:37 AM
dgreen78's Avatar
dgreen78 has a reputation beyond reputedgreen78 has a reputation beyond reputedgreen78 has a reputation beyond reputedgreen78 has a reputation beyond reputedgreen78 has a reputation beyond reputedgreen78 has a reputation beyond reputedgreen78 has a reputation beyond reputedgreen78 has a reputation beyond reputedgreen78 has a reputation beyond reputedgreen78 has a reputation beyond reputedgreen78 has a reputation beyond repute
Anyone install larger injectors? I would like to know what is involved and if they are accessible with the motor in?
Old Jul 4, 2007 | 01:38 AM
no u have to do at least a partial drop....
2001 996TT 3.6L and stock ECU
9.66
seconds @ 147.76 mph 1/4 mile
click to view
Old Jul 4, 2007 | 08:15 AM
cjv's Avatar
cjv
Moderator
You need to calculate what your air flow is so as to determine the proper size injector. Depending on the injector chosen, you may have to install larger supply and return fuel lines along with a larger fuel pump. The fuel pressure regulator also needs to be looked at.
Old Jul 4, 2007 | 08:34 AM
Dr_jitsu's Avatar
And also your MAF. Bigger injectors probably mean a whole new fuel system.
Old Jul 4, 2007 | 09:30 AM
robmd99's Avatar
robmd99 has a reputation beyond reputerobmd99 has a reputation beyond reputerobmd99 has a reputation beyond reputerobmd99 has a reputation beyond reputerobmd99 has a reputation beyond reputerobmd99 has a reputation beyond reputerobmd99 has a reputation beyond reputerobmd99 has a reputation beyond reputerobmd99 has a reputation beyond reputerobmd99 has a reputation beyond reputerobmd99 has a reputation beyond repute
The 996 turbo motor is supported by two bolts... what I have done in the past is loosen these up and they will give you a two inch drop so you can get your hands in there :-)
Robert
Old Jul 5, 2007 | 11:52 PM
dgreen78's Avatar
Thanks guys, I am doing the Proto700 kit so I will be using stock lines with stock FPR just larger injectors and an additonal fuel pump. Also the Mustang MAF
COBB Tuning
Jan 1, 2025 09:02 AM
Sales@RSW
Sep 3, 2015 09:34 AM
orbelo
Aug 30, 2015 12:26 PM
