Does anyone sell tuning software?
Old Jul 5, 2007 | 08:32 AM
Origyns 973's Avatar
Origyns 973 is a splendid one to beholdOrigyns 973 is a splendid one to beholdOrigyns 973 is a splendid one to beholdOrigyns 973 is a splendid one to beholdOrigyns 973 is a splendid one to beholdOrigyns 973 is a splendid one to beholdOrigyns 973 is a splendid one to behold
Originally Posted by PorschePhd
It is not like the GM ECUs, as far as complexity, you can look at the files until you are blue in the face and unless you have the complete program and the interpretation of the hex addresses forget. As far as complexity, well the original programming by Bosch became so complicated that software had to be written to just get start up. Form there was 100 hours on the engine dyno, then the street tuning. The newest of the TTs are 3 times more complicated than the 996TT. In addition to the software you will also need the ability to write to it, that is a whole separate subject. Bottom line a serious hobbyist is probably not going to be able to pull this off.
No, it is nothing like Motec or Haltec hence why so many people like to think piggy back is the way to go. The programs in the car are too smart and will stop you shy of 600HP FWIW.
I just got a chance to see how the Ferrari ECU's are encoded and I have to positively say 99.99% of just 'enthusiasts' won't be able to pull it off. Although its some pretty amazing stuff.
Old Jul 5, 2007 | 09:59 AM
nerdhotrod's Avatar
nerdhotrod is infamous around these partsnerdhotrod is infamous around these parts
Just by the real tuning software. It is not hard to get. There are a handful of major players...it will cost you about 15K for the base tuning software then you will need the Damos files which will cost you as well. No one is keping anyone from anything. It is just not cheap and even if you do buy it there are more maps then you can imagine in there. Witout the Damos files you are sunk.
Most of these "tuning" packages you can buy, give you access to less then 1% of available maps in the ecu.
Even with a damos, you will still have to sort through ~4300 active maps in an me7 ecu to figure out what it going on. It takes the average person (myself included) 2-3 years to really understand what is truly going on in the ecu, unless you have a significant amount of help from an outside source.
Tuning these ecus requires many things you cant just buy, ie. a high speed data logging application, in circuit emulators, a dyno ect ect.
Tuning the me7 ecu is much more involved then any other ecu I have ever touched! But once you have it dial in, its worth the time, head ache and frustration it took top get there.
Old Jul 5, 2007 | 10:01 AM
nerdhotrod's Avatar
Originally Posted by MARKSKI
From what I was told it is very limited in use... if u try to go past certain parameters it will switch maps on you... you see u need certain security codes to get around these things.... then to complicate things even more... You need the hardcore stuff to be able to do what you want it to do... maybe its good for 500 rwhp but anything beyond that I would not be so sure.
My friend uses the Revo stuff on Audi's but its very limited in use...
markski
I bet your friend uses Lemiwinks for change the addaption channels on his audi. This allows global changes to timing, fuel, load offsets ect.
If there is enough interest, I can most likely put somthing similar together for these cars.
Old Jul 5, 2007 | 10:04 AM
Tony, have you gotten the chance to play with the 997TT?
Old Jul 5, 2007 | 10:12 AM
nerdhotrod's Avatar
Not yet. I've tuned more then a few other cars with similar ecu's (MED 9).
Just waiting for a test car....
Old Jul 5, 2007 | 12:20 PM
PorschePhd's Avatar
My point exactly. That is why I always try to explain even if you have all what you need, you still will not have a clue without a hell of a lot of time or friends who BTDT to point out all the maps. It is not as cut and dry as people would like to believe. The 997TT is even worse as far as the maps are concerned and the encryption is double what the 996TT was. Nevertheless it is a wonderful setup once you gain a grasp on the entire setup.
Old Jul 5, 2007 | 01:02 PM
drewTT's Avatar
drewTT has a spectacular aura aboutdrewTT has a spectacular aura aboutdrewTT has a spectacular aura about
i want the lemmi! i hate it when my s4 buddies bust out their laptop and bam +50 hp....
Old Jul 5, 2007 | 04:23 PM
carendt242's Avatar
carendt242 is a jewel in the roughcarendt242 is a jewel in the roughcarendt242 is a jewel in the roughcarendt242 is a jewel in the rough
i had a map-ecu on my supra and, while one can take a certain amount of joy in tuning their own car, i'm glad i don't have to mess w/ it anymore. (of course, on the flipside, when something goes wrong, i have little to no visibility on what's wrong.)
- chuck
Old Jul 5, 2007 | 08:22 PM
Sonny's Avatar
Sonny has much to be proud ofSonny has much to be proud ofSonny has much to be proud ofSonny has much to be proud ofSonny has much to be proud ofSonny has much to be proud ofSonny has much to be proud ofSonny has much to be proud ofSonny has much to be proud of
Right now I'm playing with a GT2 using Lemiwinks, I'll keep you posted.,cheers, Sonny.
Old Jul 5, 2007 | 09:25 PM
Judging by your just updated signature can we make the conclusion that you picked up a GT2?
Old Jul 5, 2007 | 09:30 PM
INTMD8's Avatar
INTMD8 is a splendid one to beholdINTMD8 is a splendid one to beholdINTMD8 is a splendid one to beholdINTMD8 is a splendid one to beholdINTMD8 is a splendid one to beholdINTMD8 is a splendid one to beholdINTMD8 is a splendid one to behold
Yeah, I suppose I should have been more specific.
My experience with LS1/LS2/LS7 pcms is using HP tuners software which reads the stock calibration and allows you to change parameters in various tables.
I want no part in sorting out raw unorganized data from a foreign (to me) PCM
Old Jul 6, 2007 | 06:39 AM
Sonny's Avatar
No thats not updated it always been my sig., and that still my car (Gt2), waiting for a my new 997 Gt2 thou., order one a while back.
Mini George
Jul 29, 2019 12:20 PM
Mini George
Jan 18, 2016 09:16 PM
L.A.P.
Oct 19, 2015 10:01 PM
Just Cruise
Aug 25, 2015 10:45 AM
L.A.P.
Aug 23, 2015 11:48 PM
