Philips HID Bulbs! 6000K
Old Apr 14, 2004 | 04:58 PM
Weazel's Avatar
Weazel is infamous around these parts
Have to say if your bulbs aren't bright enough, try these on for size. Easy upgrade and install. These are real HID bulbs. These worked great in our 996. Compare the bulbs. You'll see the difference immediately. Let me know if you're interested. e-mail me or PM me for more information.
Old Apr 14, 2004 | 06:52 PM
DJ's Avatar
DJ
those are for fogs are headlights ?
Old Apr 14, 2004 | 06:56 PM
20C4S's Avatar
no Darren, those are for the headlight replacement. i wanna see how they look at night since they are really bluish.
Old Apr 14, 2004 | 07:01 PM
Weazel's Avatar
I will try to get some night pictures for you.
Old Apr 14, 2004 | 07:07 PM
HotRodGuy's Avatar
what are the #'s on the stock lights?
weazel, you guys got any 9006 conversions laying around still?
Old Apr 14, 2004 | 07:11 PM
Weazel's Avatar
The numbers are the same. "D2S" And I wish I could say there were some laying around but no, sorry.
Old Apr 14, 2004 | 08:19 PM
BCS996TT's Avatar
BCS996TT is infamous around these parts
Isnt this really more of a cosmetic thing than actually improving night time visibility?
There are a lot of guys running aftermarket 6K+ HIDS with projector headlamps which do not improve visibility over the standard 4K HIDS.
There was a write up on this floating around somewhere that went into great detail on how the standard oem HID bulbs were better than the aftermarket bluish HIDs in terms of visibility.
With that said, if you can prove me wrong, I would like to know more details about cost, etc.
Old Apr 14, 2004 | 08:31 PM
KJM3's Avatar
KJM3 is infamous around these parts
BCS996TT, you are correct.
Although the color temperature is higher on the 6,000 Kelvin bulbs, the LUMEN output is about 20% lower. Meaning it's actually approx. 20% less bright. The best color temperature is about 4,100 - 4,300K which is what the stock HID's are rated at.
However, I can safely say that the 6000K bulbs look SUPER PIMP and MAY be worth putting in if you like the look. If you go with 6000K bulbs, you should ALWAYS get genuine Phillips bulbs and not some no name ones. I would even stay away from Osram as their bulbs are not as good as Phillips bulbs.
I would personally prefer to keep the stock bulbs. If I slammed into some debris on the road at night because the 6000K bulbs didn't light the road up properly, I'd be really upset. =)
- KJ
Old Apr 14, 2004 | 09:11 PM
boston 7777's Avatar
boston 7777 is infamous around these parts
i have them... they look purple..very nice at night..
Old Apr 14, 2004 | 10:38 PM
LSM's Avatar
LSM
Senior Member
LSM is a glorious beacon of lightLSM is a glorious beacon of lightLSM is a glorious beacon of lightLSM is a glorious beacon of lightLSM is a glorious beacon of lightLSM is a glorious beacon of light
How about going with Philips 5000k DS2 xenons and the HID 5000k H3 fogs, will they match, can/will the fogs melt the casing?
Lou
Old Apr 14, 2004 | 10:44 PM
Chordate's Avatar
Chordate is infamous around these parts
Headlight replacement? I thought the Xenon was standard on the Turbo... why would you need this... I am confused
Old Apr 14, 2004 | 10:53 PM
LSM's Avatar
LSM
Senior Member
Its cosmetic. It looks bluer than the standard 4150 HID bulbs that are standard. I want the fogs to match. Right now I have PIAA 4150k hid fogs, but, they do not match.
Lou
Old Apr 15, 2004 | 12:48 AM
20C4S's Avatar
Lou,
remember we talked about this a while ago?
thought u went with the 4300K. i know the 4150k doesn't match & 4300k is the perfect match.
Old Apr 15, 2004 | 01:43 AM
dbelleperc's Avatar
I soon will be a supporting member
dbelleperc is infamous around these parts
Don't buy the bulbs unless you want you lights do be not as bright.
I posted this about 4 months ago.
The color temp is not the brightness of the light is only refering to what the light color is on a light spectrum, the lumunes is what is the factor of brightness.
A standard Philips or Osram Sylvania D2S bulb is rated at 4100K color temp but produces 3200lm +/- 450lm, while a 6000K bulb is rated at 2500lm +/- 450, and the best halogen bulb a H7 produces 3200K Temp and 1335lm @ 12.8V.
This is from a tread I posted on the 996 section:
When looking at a 12000K head on...it appears brighter because the short, medium and long cones in your eyes all have hypersensitivity in the blue wavelength range. Also the higher composition of blue wavelengths tend to radially disperse in the atmosphere which comes out in two ways: glare and decreased amount of usable light along the intended trajectory of the beam due to radila distribution. Also...blue reflects more off of wet surfaces...making them not ideal for adverse situations. Blue is not a color to drive with...fortunately its only a side effect of our OEM projectors and not a constituent to the body of the beam pattern.
I hope I saved you some trouble in the future.
Old Apr 15, 2004 | 01:48 AM
dbelleperc's Avatar
But as KJM3 said if you want the look go with it. The bulbs are Philips and that is the only company that makes a good quality 6000K bulb.
