Losing weight
HeavyChevy,
I also like you have heard in many places all the benefits related to rotational mass etc, but it has always been only speculation and sort of a black box.
What I do know is that I run heavy Cargraphic racing wheels, and with my other lighter wheels (Magnesium) , I had no impact on lap times that I could attribute to the wheels, the same with 60-130mph runs.
I am not sure I understand the relationship of this with drivetrain losses. Drivetrain losses are due to component resistance and friction (heat) mainly, the rotational mass in a torque tube is minimal , being so light and close to the center of rotation. The 2WD to 4WD conversion has been calculated to increase drivetrain losses by about 6%, based on datalogged runs, excluding weight savings.
Maybe as a point of reference, Cargraphic has been winning for three years in a row the German Tuner Grand Prix with GT3 cars fitted with their very heavy wheels, with the amount of money invested on suspension, aerodynamic and engine improvements, I would have thought that they would have started with the wheels!
Tradin1, Thanks. I posted above some names.
Sechsgang, I know what you mean, there is all sorts of speculation going on at the tracks, mostly related to butt dyno feelings or hearsay, but seldom proven with data. I doubt the impact is really meaningful other than the benefit of mass reduction of the wheels itself and some more as a result of unsprung weight. Steering input, I am definitely there, so is a reduction of rebound/better tire contact on bumpy tracks.
What I do know is that I run heavy Cargraphic racing wheels, and with my other lighter wheels (Magnesium) , I had no impact on lap times that I could attribute to the wheels, the same with 60-130mph runs. I am not sure I understand the relationship of this with drivetrain losses. Drivetrain losses are due to component resistance and friction (heat) mainly, the rotational mass in a torque tube is minimal , being so light and close to the center of rotation. The 2WD to 4WD conversion has been calculated to increase drivetrain losses by about 6%, based on datalogged runs, excluding weight savings.
Originally Posted by wross996TT
You should watch who you call what...Tom is very respected here! And what he says is correct. This has been covered at length...in fact some great threads involving Tom.
Try here:
Weight reduction...after a 20 second search.
Try here:
Personally I have no problem with anyone on this forum regardless of how they may feel about me, not really something I would loose sleep over!
thanks again
tom
GD, who gives a damn already. I asked a simple question. I am pretty sure the majority of topics have been discussed, screw the search function
I wanted to get some more opinions
Christian
Christian
Christian
Christian
good luck.
tom
In bike racing, ignoring the drug issues, the lightest wheels are not always best because of:
durability
stability at speed
ability to hold roundness (stiffness in climbing/cornering).
In cycling, data exhist for why light stuff is better in terms of work needed to go up hill, in particular, and in sprinting (acceleration). At steady state, it is not as big a deal.
Perhaps, and only perhaps, these issues impact real world use of car wheels.
When I got my new 996TT, I asked if the hollow wheels were ok. Mechanic who had a lot of scca time said to me: light and strong as hell. In some ways, probably the best wheel you'll ever find for the money. So I stuck with them. I am sure there are better wheels, etc. But these are quite strong and pretty light.....to me, I want a reliable wheel. And, once in a while one can get them for 300 or so each in sets of four. :-)
JB
durability
stability at speed
JB
Originally Posted by Jean
HeavyChevy,
HeavyChevy
Different diameter wheels will certainly have an impact on acceleration rate, however it is also speed dependent, while it has a benefit in off the line acceleration (provided you can keep them gripping), it does not give any improvement at higher speeds where acceleration levels have milded down.
It is a simple formula in fact:
Torque put to the ground= Torque at the axle / (rolling diameter (In.)/2/12 )
So If the torque coming to the wheel is 1000 lbs, then the thrust put to the ground for example is 961lbs with a 295/30 x18 and 988lbs with a 265/35 x 17 , not much difference.
With a taller tire you will have a bit less acceleration and more weight but much bigger contact patch and sidewall, which is why they prioritize that over smaller diameter wheels and tires that are lighter.
996-997 RSR run the tallest possible tires they don't need the additional torque coming from a smaller diameter tire.
Sorry to go OT Christian. I will stop here with the wheel/tire thing.
HeavyChevy
Originally Posted by heavychevy
How does weight translate in that formula.
Weight will come in the next step, when you want to measure acceleration impact in ft/s.sq. , you take weight and circumference into the equation.
We can take it offline if interested.
Jean
ECS Tuning - BMW
Sep 10, 2015 02:51 PM
