Code 5525
Old Jul 15, 2007 | 06:33 PM
Gunther's Avatar
Gunther Is a GOD !Gunther Is a GOD !Gunther Is a GOD !Gunther Is a GOD !Gunther Is a GOD !Gunther Is a GOD !Gunther Is a GOD !Gunther Is a GOD !Gunther Is a GOD !Gunther Is a GOD !Gunther Is a GOD !
Code 5525
Has anyone ever gotten this DME code (5525) and know how to fix it? It has disabled my PSM and ABS and can not be reset with the scan tool.
Any comments would be much apprecaited.
Old Jul 15, 2007 | 06:54 PM
wross996TT's Avatar
Uh...don't know of a fault code starting with 5:
Fault Types
Type 1 Signal implausible/implausible operating range/malfunction
Type 2 Open circuit/no signal
Type 3 Short to ground/below lower limit/lean mixture threshold
Type 4 Short to B+/above upper limit/rich mixture threshold
Note: M150 is for required for the following countries - Russia, Cyprus, Brazil, Equador, Middle East (for all connected markets), Costa Rica, Venezuela, Columbia, Peru, Mexico, and China
Check Engine MIL
0 Function deactivated
1 CE is flashing, fault damaging to TWC
2 CE is on, emission relevant fault
3 CE is on after 2 driving cycles
6 CE is off, emission relevant fault 7 Fault caused by short test
11 Fuel supply fault, CE is on after 2 driving cycles, higher freeze frame priority
30 CE is on after 3 driving cycles
31 CE is on after 3 driving cycles with misfires
33 Fuel supply fault, CE is on after 3 driving cycles, higher freeze frame priority
* In the event of misfiring faults, the fault types have a different meaning.
Fault type 1: Emission relevant fault after start-up
Fault type 3: Emission relevant fault during the journey
Fault type 4: Fault damaging to TWC
** In the event of oxygen sensor faults, the fault types have a different meaning.
Fault type 1: All electrical faults (open circuit, short to B+ or ground) lead to this fault output
Fault type 2: Injection of oxygen sensor heating into the sensor signal
Fault type 3: Oxygen sensor aging fault, sensor dynamics
Fault type 4: Oxygen sensor aging fault, sensor contamination, characteristic shift
Old Jul 16, 2007 | 06:51 AM
Gunther's Avatar
Thanks for the comments and information.
Not often are the fault codes over 2000+ But for DME or non engine related they can go this high. Not having the ABS and PSM is kind of a pain.
Old Jul 16, 2007 | 07:27 AM
kris's Avatar
kris is infamous around these parts
COuld be a blown MAF sensor or a boost leak.
Old Jul 16, 2007 | 07:52 AM
buddyg's Avatar
Blown MAF
I understand that there have been reports of air mass sensor failures (fault code "5525") leading to anti-lock braking system (ABS) and Porsche stability management (PSM) failures.
The on board computer screen may read "ABS failure - Drive to workshop" or "PSM failure - Drive to workshop".
This was from the PCA tech forum.
Old Jul 16, 2007 | 01:20 PM
MX RACER's Avatar
MX RACER is infamous around these parts
Both times my maf blew the abs and psm lights came on.. The car still seemed to run fine, but the dealer said it was the maf and the maf fixed it..
Old Jul 16, 2007 | 02:09 PM
Onetime's Avatar
Onetime has a brilliant futureOnetime has a brilliant futureOnetime has a brilliant futureOnetime has a brilliant futureOnetime has a brilliant futureOnetime has a brilliant futureOnetime has a brilliant futureOnetime has a brilliant futureOnetime has a brilliant futureOnetime has a brilliant futureOnetime has a brilliant future
I had a similar problem and it turned out to be the throttle body. I replaced it and the lights cleared and PSM and ABS worked again.
Old Jul 16, 2007 | 07:12 PM
Gunther's Avatar
Thanks for all the comments guys. I will replace the MAF and see what happens. I just have a hard time thinking it is the MAf because it is running crazy good like it always does.
I'll let you know if that does the trick or not.
Old Jul 16, 2007 | 07:13 PM
Gunther's Avatar
Originally Posted by buddyg
Blown MAF
That is exactly what is says so like my other post said I will give the MAF a try. Thanks for the comment!!!
Old Jul 16, 2007 | 07:23 PM
Turbo Fanatic's Avatar
Probably a MAF. Do you have an after market intake?
The car seems to run fine with blown MAF (sometimes), but most of the time it is running rich as a failsafe. Running for extended periods can cause catalytic failure and carbon buildup in the engine (in severe cases).
Your catalytic is basically an oven that burns unburned fuel, running rich burns up the oven....
Old Jul 16, 2007 | 07:28 PM
Gunther's Avatar
Yea I have the EVO intake with a non-oiled filter. This is the original MAf with 30,000+ miles so maybe it is just due?
Old Jul 24, 2007 | 09:53 AM
Gunther's Avatar
The replacement of the MAF cleared the code. No more problems.
Old Jul 31, 2007 | 07:38 PM
Al Pettee's Avatar
Al Pettee is a jewel in the roughAl Pettee is a jewel in the roughAl Pettee is a jewel in the roughAl Pettee is a jewel in the rough
I blew the MAF on mine last summer with the EVO stage 4/600 package (ABS and PSM failure/CEL lighted up too), and I thought mine was faster afterwards also. Replacing the MAF (same Bosch piece) rectified that and it has held this summer on the GT700 upgrade.
Old Jul 31, 2007 | 07:48 PM
landjet's Avatar
Are these blown MAF's a result of power mods or something else?
Old Jul 31, 2007 | 07:52 PM
oak's Avatar
oak
did you try a throttle body alignment?
