IPD plenum and throttle body
Old Jul 21, 2007 | 02:41 PM
RCNJ's Avatar
RCNJ is infamous around these parts
Has anyone used IPD's 996tt plenum and there bored throttle body?
My GT2 is at Protosport getting the Protomotive 700 and I was originally going to leave the stock TB and plenum but after seeing Marty's result with this setup I decided to go the same route. The difference is Todd made Marty's Y-pipe to fit the 997na TB and my Y-pipe is made to fit my TB which is smaller. Now IPD makes a bored TB to fit the stock Y-pipe and the 75mm plenum. I'm just wondering if there is a difference between these two setups.
Raudel
Old Jul 21, 2007 | 03:13 PM
Dr_jitsu's Avatar
I like them very much....however they are overpriced. You can adapt a stock 997 throttle body for much less and the plenum is $40 of material for $1100. I know that R&D is expensive, but the plenum should not be more than $800-900 tops.
And yes, you need the Y pipe...more money. Of course if the new IPD TB fits the Y pipe that saves money...how much is it, and how does one contact IPD? The bottom line is that I would love to have the 75 MM throttle body and IPD/RSS plenum, they will definately increase responsiveness and add some noticeable hp. It is just that there are much more cost effective mods.
If IPD/RSS want to come down in their price a bit I will give them my credit card today (please PM if so....lol). Maybe we can convince them to do a group buy. If the numbers purchased go up the prices should be able to come down.
Old Jul 21, 2007 | 04:20 PM
WOODTSTER's Avatar
Raudel,
I do not know the answer but I can tell you I tried high boost today (100
octane) for the first time and the car just "Jumps"; It really feels strong!
You are going to have SO MUCH fun very soon. Maybe go with what will fit
your car (IPD). I believe Todd said the larger TB helped in the midrange mostly (had more torque than Divexxtreme's first set-up which did NOT have
the larger throttle body). Please nobody confuse Divexxtreme's current set-up to what I am comparing to.
GO for larger TB !!!
MK
Old Jul 21, 2007 | 04:25 PM
Dr_jitsu's Avatar
What is the price for the new IPD TB that fits the stock Y pipe?
Old Jul 21, 2007 | 05:08 PM
dgreen78's Avatar
dgreen78 has a reputation beyond reputedgreen78 has a reputation beyond reputedgreen78 has a reputation beyond reputedgreen78 has a reputation beyond reputedgreen78 has a reputation beyond reputedgreen78 has a reputation beyond reputedgreen78 has a reputation beyond reputedgreen78 has a reputation beyond reputedgreen78 has a reputation beyond reputedgreen78 has a reputation beyond reputedgreen78 has a reputation beyond repute
Raudel, the only thing that needs to be modified on your Y-pipe is the small section between the MAF and TB (10" of pipe) cut off and a larger piece welded on. Then you can use the 75mm TB with the larger plenum.
Have you seen the ID of the stock Y-pipe? It is VERY small (<2"). Todd's Y-pipe uses 2.5"
I agree on the group buy! If someone get one going I will be in for sure.I think if they brought there price down a bit they would for sure sell more of them making up for the cost reduction IMO.
Old Jul 21, 2007 | 05:41 PM
adybuncio's Avatar
I have both mods on my C2, wouldnt go back to stock after these two mods. Power delivery is very smooth and noticeable. And the sound that my intake makes now is even better and fuller.
Old Jul 21, 2007 | 05:59 PM
996TT_STEVO's Avatar
996TT_STEVO has a reputation beyond repute996TT_STEVO has a reputation beyond repute996TT_STEVO has a reputation beyond repute996TT_STEVO has a reputation beyond repute996TT_STEVO has a reputation beyond repute996TT_STEVO has a reputation beyond repute996TT_STEVO has a reputation beyond repute996TT_STEVO has a reputation beyond repute996TT_STEVO has a reputation beyond repute996TT_STEVO has a reputation beyond repute996TT_STEVO has a reputation beyond repute
So can someone explain how the 700 kit works here, no airbox!
Old Jul 21, 2007 | 06:56 PM
John D's Avatar
John D is a splendid one to beholdJohn D is a splendid one to beholdJohn D is a splendid one to beholdJohn D is a splendid one to beholdJohn D is a splendid one to beholdJohn D is a splendid one to beholdJohn D is a splendid one to behold
Stevo,
Twin air filters are located on each side just above the intercoolers and plumbed directly to the turbo fresh air intake. The diverter valves are relocated to the intercooler and vented to the air. The MAF works with boosted air vs. fresh non-boosted air. Here is a picture of an install in process - look closely because it's a little hard to see:
Old Jul 21, 2007 | 07:14 PM
Got ya John, If I remember correctly it was Craig that done that with the filter a while back, makes sense as it is geting better cool air flow.
Old Jul 21, 2007 | 07:34 PM
cjv's Avatar
cjv
Moderator
Actually the reason is it allows for larger air intake diameter which is required on turbo's like the GT30 and 35's. The room just isn't there following the route of the factory lines. In addition it is also a far shorter route. Again allowing for more air volume.
Old Jul 21, 2007 | 07:47 PM
oak's Avatar
oak
I wonder how many laps it would take before it would heat soak.
Old Jul 21, 2007 | 11:23 PM
RCNJ's Avatar
Sean- The IPD TB is $350
Marty- Great to here all the fun you're having ... can't wait get mine running.
Don- I'm trying to see if I can get away with doing the IPD TB so I won't have to modify the Proto Y-pipe.
Old Jul 22, 2007 | 11:10 AM
WOODTSTER's Avatar
Arrow Protomotive 700 kit
Oak, you ornery old coot, I already told you that I ran in the hot
sunny weather this week ***** out for 20-30 minutes at Road America and no heat soak.
Of course I have better I/C than the ones pictures... .
MK
Old Jul 22, 2007 | 12:38 PM
oak's Avatar
oak
you did? how many sessions?
Old Jul 23, 2007 | 08:14 AM
buddyg's Avatar
Yeah I only get to do one 60 to 130 mph run and then my power is down 50% from heat soak!
