FVD 996TT Programming
#63
Originally Posted by porschedude996T
Simple question that may have been over looked. Can you flash back and forth from OEM and Customized as many times as I want?
I have no affiliation with FVD..fwiw.
#64
There are no limites to the number of times the ROM can be flashed with different files, beyond the limits of the chip itself, which is about 100 or so times before they become unstable. The limit you speak of is the number of times the security/immobilzer can be reset for different cars. Your ecu can only be reprogrammed to be switched to 6 different vehicles. Actually I think its 7...but whatever.
#65
The reason I ask about how many times is due to the polution controls today here in california. How about detection by the smog inspection natzi's? Can the flash changes be detected?
#70
The softronic software FVD uses is supposed to be undetectable by Porsche, Smog, and everybody else except Softronic who does PCA testing as well...
Even a PIWIS won't see it...
At least thats what Softronic says....
dw
dw
#71
dw
dw
#72
Originally Posted by ari
Now get some upgraded wastegates. You haven't seen anything yet. The muddy feel will be replaced by much crisper throttle response, more midrange torque and you'll hold 1.2 BAR to redline.
Do you have an exhaust? I strongly recommend it as well.
#73
Could someone clairify what is meant here. I thought the Waste Gates were in the turbine housing. Are we talking about the wastegate actuator (Pod, bracket and Rod)???
#74
I just want to make sure I understand the original post. I can take my completely stock 996TT that makes 415hp and flash it with this program and it will make 490hp with no actual modifications other than the reprogramming?
#75
