Quick question !
Quick question !
Can someone varify for me the RPM drop between 3rd and 4th gears? Lets say next time any of you are out and about... take the car to 6500 rpms in 3rd and then shift to 4th( and please check the RPMs it dropped to).
I would like to get a consensus from two members so it is collaborated just in case one is off.
Sorry for this strange request but I have a hunch I'm working and it's bugging me to death.
best,
markski
best,
markski
2001 996TT 3.6L and stock ECU
best,
markski
best,
markski
+1 on Dr. Joe's question. The answer (a specific number of RPMs) is
dependent on how fast you're going when you change. You could
alternately just give us the RPM at which you shift from 3 to 4.
For instance if you're doing 5 mph in third when you change up, the
RPM drop is 233 RPM
RPM drop is 233 RPM
Markski,
With your tire sizes and shifting at 8K RPMs: (Bold is speed in mph, and the other is new RPMs after shifting)
1st Gear 46.1 -- 4460 From 6500RPMS: 3624
2nd Gear 81.8 -- 5194 From 6500 RPMS: 4220
3rd Gear 124.7 -- 6291 From 6500 RPMs: 5111
4th Gear 157.0-- 6859 From 6500 RPMS: 5573
5th Gear 181.3-- 6124 From 6500 RPMS: 4976
6th Gear 234.5
Sorry for the poor formatting
6th Gear 234.5
.best,
markski
I should have paid attention on the way to work this morning. Made a 3rd to 4th pull on the freeway, but only was watching the boost (which was only disappointing LOL).
On the way home tonight I'll make a pass, but you'll probably have an answer by then.
Jean, I meant stock 295/30/18s... I just want to know for sure what it should be.... so some real data would be great.
Originally Posted by Jean
Markski's tires are not stock size, that will represent a small difference...In my calculations I also factor estimated tire deformation.
shifting from 3rd to 4th, so it's irrelevant to the RPM drop.
Joe, you are 100% right, I was thinking of the speed and talking of RPMs, apologies.
Mark, with stock tire sizes, drops are per/close to Joe's numbers. I can send you a spreadsheet if you want.
OK thanks for the input....
I believe the 4th gear RPM drop is also going to be dependent on how quickly the shift was made. It would seem to me that the slower the shift is made, the more speed is bled off, hence when the clutch comes out and re-engages the drivetrain the RPM would be lower than it would with a speed shift.
