Help with Malfunctioning Turn Signals
Old Apr 22, 2004 | 02:51 PM
Under PSI's Avatar
Under PSI has much to be proud ofUnder PSI has much to be proud ofUnder PSI has much to be proud ofUnder PSI has much to be proud ofUnder PSI has much to be proud ofUnder PSI has much to be proud ofUnder PSI has much to be proud ofUnder PSI has much to be proud of
My car has developed an interesting problem and is going in to the dealer to fix it under warranty but I thought I'd ask here if there is something I may be overlooking.
Last weekend my driver's side front turn signal stopped working. I checked the bulb and the socket and swapped them side to side. The bulb from the driver's side does work when I put it in the passenger's side socket but will not work on the driver's side. All other lights worked fine until today. Now the passenger side turn signal is doing the same thing. Neither signal is working properly but the passenger side is only intermittent. Fuses have been checked and the lights are seated properly. Any ideas? The headlights, driving lights, tail lights all work fine. Four way flashers do not work in front although the passenger side is intermittent just as with the turn signal lever.
Old Apr 22, 2004 | 07:10 PM
Tool Pants's Avatar
Tool Pants is infamous around these parts
My guess. The flasher relay, then the hazard switch.
Old Apr 23, 2004 | 08:54 AM
Under PSI's Avatar
Thanks.
airbusdrvr
Dec 27, 2015 07:43 PM
JQGS
Oct 18, 2015 06:19 PM
need4speedmotors
997 Turbo Vendor Classifieds
Sep 28, 2015 04:47 PM
WEEED
Cayenne
Sep 25, 2015 10:45 PM
Zero911
Sep 24, 2015 06:33 PM
