How low to go?
Old Aug 14, 2007 | 08:19 PM
landjet's Avatar
How low to go?
I searched and found some info but would like to put this to the experts. My 993 was lowered before I got it, so I wasn't really involved in the process. My 996TT needs to go down from stock height. Would like feedback about how low you lowered your car and why. Any suggestions for best ride height for street and some DE's? How much actual distance is there from stock height to GT2 height?
Old Aug 14, 2007 | 09:54 PM
AG996LV's Avatar
AG996LV is infamous around these parts
If you drive 90% or more on the street, PSS9's are good and inexpensive. I did the PSS9's and I am very happy with the results. It is above GT2 height but slightly lower than X73 I believe. I already scrape the front lip occasionally, any lower and it would be worse. I couldn't stand the look of the stock height, and the car rides and handles great for the street. If you are looking for more of a track setup, then Motons are the way to go, and more $$.
Old Aug 15, 2007 | 01:18 AM
kzrsoize's Avatar
kzrsoize is infamous around these parts
Motrons are awesome, but for about 7k more.....id rather put that money into wheels or speed....
Old Aug 15, 2007 | 01:06 PM
landjet's Avatar
I know many here have lowered their cars. Please help me out with your knowledge.
Old Aug 15, 2007 | 02:09 PM
Shark01's Avatar
Shark01 is just really niceShark01 is just really niceShark01 is just really niceShark01 is just really nice
I'm getting JICs put on later this month and I intend to go about an inch lower.....so about 1/4 inch higher than a GT2.
Old Aug 15, 2007 | 02:50 PM
landjet's Avatar
So are you saying there is 1.25 inches of difference from stock height to GT2 height? What would RS height be then?
Old Aug 15, 2007 | 08:32 PM
fly2low's Avatar
fly2low is infamous around these parts
I am getting JICs put on right now. Going for 1.5 inches lower. Got the new JICs with the improved sway bar mounts. Price is higher than PSS9s, but by all reports better, esp when lowering the car. Comes with front camber plates. Can't say yet how I'll like it, but can't wait to find out.
Old Aug 15, 2007 | 08:44 PM
landjet's Avatar
Please report back.
Old Aug 15, 2007 | 09:14 PM
cohare's Avatar
cohare has a spectacular aura aboutcohare has a spectacular aura aboutcohare has a spectacular aura about
Just did mine, the best thing is that 90% of the options are adjustable coil overs so you can set it up to your liking. Its pretty easy to adjust them when they are on the car.
I just did the H&R - have it at the lowest setting in front and the rear is almost at the highest setting (much more adjustablility on the rear). I will test it out for a little before getting it realigned, if I want it lower or higher I can change it easiliy. You are welcome to take mine for a drive and see how you like it...
Old Aug 15, 2007 | 10:35 PM
kzrsoize's Avatar
just got my jic cross overs....love em....i went 1 1/2'' lower than stock height and used the gt2 rack set up....i wish i had gone a little lower but thats ok because at only at 1 1/2'' im already scrapping my driveway if i dont come up at wide enough angle. I measured from the bottom of front end lip to ground.
Old Aug 16, 2007 | 11:37 AM
Onetime's Avatar
Onetime has a brilliant futureOnetime has a brilliant futureOnetime has a brilliant futureOnetime has a brilliant futureOnetime has a brilliant futureOnetime has a brilliant futureOnetime has a brilliant futureOnetime has a brilliant futureOnetime has a brilliant futureOnetime has a brilliant futureOnetime has a brilliant future
Kzrsoize who did the install on your JIC suspension.
Old Aug 16, 2007 | 12:53 PM
kzrsoize's Avatar
Hey Andre,
Loren at 911design...install alignment with corner balancing.....sweet ride....
marcelo
Old Aug 16, 2007 | 12:55 PM
kzrsoize's Avatar
Adjustments appear to be easy only keep in mind, when they are lowered or raised after the origianl install alignment, the car must be realigned....
Old Aug 16, 2007 | 02:23 PM
WOODTSTER's Avatar
There is a spec for the X-73 ride height,
this sits between the US standard ride height and the GT2 ride height,
this is what I have and I have no problems cornering or scraping.
Someone can elaborate perhaps?
Also, I have Cross/JIC suspension
MK
Old Aug 16, 2007 | 03:11 PM
vividracing's Avatar
I have a full spec sheet on a GT2 alignment which you should have done when it is corner balanced. I would go about 1.5" drop. JIC Cross is the best in my opinion.
