Rear Wing Removal?
Old Aug 31, 2007 | 07:04 PM
CarNerd's Avatar
CarNerd has a brilliant futureCarNerd has a brilliant futureCarNerd has a brilliant futureCarNerd has a brilliant futureCarNerd has a brilliant futureCarNerd has a brilliant futureCarNerd has a brilliant futureCarNerd has a brilliant futureCarNerd has a brilliant futureCarNerd has a brilliant futureCarNerd has a brilliant future
Rear Wing Removal?
So i'm trying to lighten the back end of this baby up a bit and i figured if i remove/replace...
-the rear wiper motor (6lbs)
-the rear subs and frame (20lbs)
-stock exhaust (30 lbs)
-stock wheels (4lbs)
-and the rear wing motor (30lbs)
...i can roughly lose about 90lbs off the rear end. My question is then... Is removing the rear wing motor an easy DIY or how much can i expect to pay to have a tuner do it? And the car will be tracked quite a bit so i'm thinking that i'll leave the blade in the up position to maximize down force. Any thoughts on any of this is greatly welcomed! Thanks!
Old Aug 31, 2007 | 08:42 PM
Ryan in SD's Avatar
Ryan in SD is a name known to allRyan in SD is a name known to allRyan in SD is a name known to allRyan in SD is a name known to allRyan in SD is a name known to allRyan in SD is a name known to all
30lbs for the wing motor? I know Im out of place here but that sounds very optimistic. I had to ditch all kinds of stuff in the 951 to lose 90lbs including the spare tire, jack, rear seats, etc..
Old Aug 31, 2007 | 11:26 PM
CarNerd's Avatar
Hm... 20lbs for the rear wing motor? And definitely not out of place. Anyone done this know how much the rear wing motor weighs? Scott?
Old Sep 1, 2007 | 10:56 AM
TKDalumni's Avatar
TKDalumni is just really niceTKDalumni is just really niceTKDalumni is just really niceTKDalumni is just really nice
Here is the best weight removal thread https://www.6speedonline.com/forums/...weight+removal
DMK stated 30-35lbs for the wing motor..
Old Sep 1, 2007 | 11:31 AM
CarNerd's Avatar
That's where i saw that.
Old Feb 26, 2008 | 05:18 AM
contigo's Avatar
contigo has a brilliant futurecontigo has a brilliant futurecontigo has a brilliant futurecontigo has a brilliant futurecontigo has a brilliant futurecontigo has a brilliant futurecontigo has a brilliant futurecontigo has a brilliant futurecontigo has a brilliant futurecontigo has a brilliant futurecontigo has a brilliant future
The actual motor doesnt weight 30 lbs for sure, go to this link that is what you want https://www.6speedonline.com/forums/...t=wing+removal
Old Feb 26, 2008 | 10:12 AM
CarNerd's Avatar
I read through that and couldnt find the weight?
Old Feb 26, 2008 | 07:27 PM
contigo's Avatar
Old Feb 26, 2008 | 08:37 PM
CarNerd's Avatar
WTF?! There is no mention of the rear wing motor weight in any of those links. If you disagree with DMK's estimated weight of 30lbs just say what you think it weighs for cryin out loud!
Old Feb 26, 2008 | 08:46 PM
contigo's Avatar
I have it off, I can weight it tomorrow I was sending the links for you to have instructions to remove
Old Feb 26, 2008 | 08:58 PM
CarNerd's Avatar
You could have said that with the links. Glad you cleared that up, i was gettin pissed man!
Jul 29, 2019 11:13 AM
orbelo
Aug 30, 2015 12:26 PM
undefnd
16
Aug 26, 2015 07:59 PM
The Oss
Aug 24, 2015 08:19 PM
