How do I get my barrell of Race Gas open!
Old Sep 13, 2007 | 03:31 PM
buddyg's Avatar
Okay I have banged and used pliers and I cannot get the top open on my race gas barrell!
HELP!
Old Sep 13, 2007 | 03:36 PM
sdorn's Avatar
sdorn is infamous around these parts
Get a can opener!!
Ag Surfer's Avatar
Ag Surfer is infamous around these parts
Do you have a blow torch?
Old Sep 13, 2007 | 03:38 PM
Eric523's Avatar
Eric523 is infamous around these parts
...bung wrench
sdorn's Avatar
NOOOOOOOOOOOOOOOOO!!!!
You gotta be careful with ideas like that. Someone might just try it!
KABOOOOM!!!
Old Sep 13, 2007 | 04:47 PM
NelsonF's Avatar
NelsonF is a splendid one to beholdNelsonF is a splendid one to beholdNelsonF is a splendid one to beholdNelsonF is a splendid one to beholdNelsonF is a splendid one to beholdNelsonF is a splendid one to beholdNelsonF is a splendid one to beholdNelsonF is a splendid one to behold
Race gas
Funny, I've had the same problem. I'm sure VP has a better tool but I end up using vice grips clamped onto middle of the cap and a screw driver wedged between the vice grip to turn. Works ok. Will you be using low boost at the track? I know you've strengthened internals but I'd be careful with the boost.
Have fun!
Old Sep 13, 2007 | 05:05 PM
mambodave's Avatar
mambodave is infamous around these parts
tap it like a keg.
Old Sep 13, 2007 | 05:18 PM
unvmy996's Avatar
hey fellas how many gallons is that drum of racegas ?? and how much do they go for ?? im looking to get one also..
Old Sep 13, 2007 | 05:30 PM
rico930's Avatar
Junior Member
rico930 is infamous around these parts
buddy you need one of these...
check with Grainger or Mcmaster Carr but i know you want in right away so try clamping vise grips vertically on the plug and putting a big cresent wrench on the v grips to turn it open. I have done this when i can't find our wrench in our the fuel room
Old Sep 13, 2007 | 05:33 PM
vividracing's Avatar
Damn i wanted to use the Blow Torch joke...
Ours is a simple top offset that you can twist off with a crescent wrench. If you need pics let me know.
Old Sep 13, 2007 | 07:50 PM
sdorn's Avatar
Be very careful to to make any sparks!! Those things can explode because of static discharge, too.
What do you guys do about getting the permits necessary to store that much fuel?
Old Sep 13, 2007 | 07:52 PM
buddyg's Avatar
Thanks for the real answers guys! The rest of you suck!
Old Sep 13, 2007 | 08:11 PM
buddyg's Avatar
This isn't a reverse thread is it? I just put 2 crescent wrenches on and couldn't budge it turning to the left?
Old Sep 13, 2007 | 08:23 PM
buddyg's Avatar
Finally got it! Dang that thing was on tight!
I am planning on running the pump program which is plenty fast but I want to use the good fuel as well.
This is a 30 gallon drum which should last for the weekend I hope!
Old Sep 13, 2007 | 08:44 PM
S-351's Avatar
S-351 Is a GOD !S-351 Is a GOD !S-351 Is a GOD !S-351 Is a GOD !S-351 Is a GOD !S-351 Is a GOD !S-351 Is a GOD !S-351 Is a GOD !S-351 Is a GOD !S-351 Is a GOD !S-351 Is a GOD !
HELP!
LOL...If you cant get it open, you should not be using it.
