Engine ping/studer
Old Sep 25, 2007 | 01:00 AM
f1crazydriver's Avatar
f1crazydriver Is a GOD !f1crazydriver Is a GOD !f1crazydriver Is a GOD !f1crazydriver Is a GOD !f1crazydriver Is a GOD !f1crazydriver Is a GOD !f1crazydriver Is a GOD !f1crazydriver Is a GOD !f1crazydriver Is a GOD !f1crazydriver Is a GOD !f1crazydriver Is a GOD !
Engine ping/studer
I had the 30k service done at 27,000 miles and the car currently has 30,400 miles. I'm getting a slight ping under hard acceleration in 3rd and 4th. Also i have noticed that my boost isnt going to the maximum. It only reaches .8 - .9 instead of the 1.0. I added half a tank of 100 octane to see if it was the gas i was using but i still get the ping. Weather here in the Bay Area is around 56F early morning and late at night, so i'm as what the problem maybe.
Any suggestions ? perhaps a boost leak somewhere ?
TIA
Enrique
Old Sep 25, 2007 | 09:52 AM
WOODTSTER's Avatar
Have James at Sharkwerks take a look.
Old Sep 25, 2007 | 09:55 AM
PIng usually means detonation....
whatever they did they screwed something up... did u do it at a dealer?
Plugs? misfire? bad coil?
2001 996TT 3.6L and stock ECU
9.66
seconds @ 147.76 mph 1/4 mile
click to view
Old Sep 25, 2007 | 09:58 AM
Highhats's Avatar
Highhats is a splendid one to beholdHighhats is a splendid one to beholdHighhats is a splendid one to beholdHighhats is a splendid one to beholdHighhats is a splendid one to beholdHighhats is a splendid one to behold
agree with mark, check spark.....
S
Old Sep 25, 2007 | 02:47 PM
Nicolas Kiesa's Avatar
Nicolas Kiesa is infamous around these parts
Or have some diagnostiscs connected whilst runing, you could also have a faulty fuel pump which will cause fuel press drop so the DET is not from aggresive ignition curves but fuel starvation/running lean = dangerous!!! So get it checked asap..
Im suprised the Throttle body does not shut down as the Bosch program tuned or not has a function to to protect the engine and shut it down.
Nicolas K.
www.kismo.dk
Old Sep 25, 2007 | 03:08 PM
wross996TT's Avatar
My guess..coil pack FWIW.
Old Sep 25, 2007 | 06:50 PM
killerbee's Avatar
killerbee is infamous around these parts
What makes you think it was pinging ? Generally things do not last too long when that happens (much less under boost). More like it developed a miss ?
Old Sep 25, 2007 | 09:55 PM
oak's Avatar
oak
cracked heads.
Old Sep 25, 2007 | 11:25 PM
Thanks guys for all your replys, i really appreciate it.
Hm, when i got the 30k service done, the car still had hesitation/ping misfire in cylinder 3 and 6 i believe. I took it to another porsche dealership, and they changed the plugs around and told me if it happens again to bring it in. Well it went away ( that was about 2,500 ago), but the other day a friend wanted a small drag race, and the ping started up again. So i guess i have to take her back in so it can be checked out. The car is no fun with the ping .
Jul 29, 2019 11:13 AM
saline
Oct 7, 2015 07:29 AM
vr6tee
Aug 29, 2015 03:52 AM
The Oss
Aug 24, 2015 08:19 PM
