Clutch Masters Stage 3 Clutch Special $1000!!!!
So many 6speeders use it. We run it in our 800HP 997TT. Perfect engagement, amazing capacity. Must have as a replacement clutch.
Want more info, go here - http://www.vividracing.com/catalog/c...5-p-49671.html
So why so cheap?
Clutch Masters uses OEM stock pressure plates and clutch disks from Sachs that are then beefed up to the Stage 3. A majority of the $1800 retail price is these components. Whenever your clutch goes bad, the actual hardware is fine. Clutch Masters can do a Stage 3 rebuild on your OEM clutch the same they do with their new kits. Full disk with fiber tough on 1 side and steel backing on the other. Custom application for Vivid Racing customers only! Fiber Tough is less abrasive then kevlar on a flywheel but holds the same.
How does this work?
http://www.youtube.com/watch?v=jIstk...layer_embedded
There is no difference between doing this and buying a new one off the shelf as all parts are rebuilt and replaced! Is your stock dual mass flywheel worn out? Upgrade to the Clutch Masters single mass flwheel. Saving over 20lbs of rotational weight, this flywheel gives you quicker throttle response, helps the turbos spool faster, and improves launches.
Special Flywheel Price - $950 shipped.
http://www.youtube.com/watch?v=Js_B5...layer_embedded
So why so cheap?
How does this work?
- Remove your Clutch
- Call Us to place the order
- Receive Return Form to Send in Clutch
- Clutch Masters Upgrades
- Vivid Racing pays for return overnight shipping!
Labor is about 9 hours.
Clutch Masters is no longer doing the rebuilds as it was a 1 time special for me. The risk of damaging the disks when you remove the rivets is to great.
We keep instock BRAND NEW KITS for $1600ish.
ECS Tuning - VW
Aug 27, 2015 02:44 PM
1000, 3, 6speedonline, 996, 996tt, clutch, clutchmaster, clutchmasters, mass, master, masters, single, special, stage, turbo
