Wheel Cap removal Q...
Old Jan 7, 2008 | 10:34 AM
NIKAS's Avatar
NIKAS is infamous around these parts
Question Wheel Cap removal Q...
Hi everyone - Santa Claus delivered a new set of 4 OEM coloured crest wheel caps and now I'd like to get them on!
Q. Assuming that do not have local access to the "Genuine Porsche Wheel Cap Removing Tool", how does one safely remove the older faded ones without breaking the cap, the cap retention teeth, or scratching the wheels?
Some of the older crests are in okay condition, so ideally I'd like to preserve a couple as spares, or for donation to fellow p-car clubbers with split, faded, or beat up ones.
Old Jan 7, 2008 | 01:33 PM
Redridge's Avatar
use an allen wrench (the "L" shape type)... stick one small enough through the hole on the wheel cap and pull!
Old Jan 8, 2008 | 10:12 PM
porschenut911's Avatar
porschenut911 is infamous around these parts
I use a small flathead screw driver and then an old credit card to pry it out, be careful and go slow.
Old Jan 8, 2008 | 10:17 PM
Wheel Dynamics's Avatar
Wheel Dynamics has a reputation beyond reputeWheel Dynamics has a reputation beyond reputeWheel Dynamics has a reputation beyond reputeWheel Dynamics has a reputation beyond reputeWheel Dynamics has a reputation beyond reputeWheel Dynamics has a reputation beyond reputeWheel Dynamics has a reputation beyond reputeWheel Dynamics has a reputation beyond reputeWheel Dynamics has a reputation beyond reputeWheel Dynamics has a reputation beyond reputeWheel Dynamics has a reputation beyond repute
You can make your own tool using a coat hanger and something to bend it in shape for you!
12" piece, fold in half bend each end (1/2 inch) in the same direction like little feet...
Easy...
-Eli
Old Jan 9, 2008 | 02:29 PM
waipahu996's Avatar
waipahu996 is infamous around these parts
1. Remove lug nuts
2. Remove wheel.
3. Push out center cap from the inside.
4. Be careful and go slow, so as not to break the little plastic clasps.
5. Remount wheel.
6. Proceed to next wheel.
7. You will have to do this procedure 4 times, so don't lose track.
8. Hope that helps!!!
Old Jan 9, 2008 | 05:16 PM
newport996's Avatar
newport996 is infamous around these partsnewport996 is infamous around these parts
Thats all you gotta do..no damage done to the cap at all....
Old Jan 10, 2008 | 12:41 AM
Duane996tt's Avatar
Duane996tt has a reputation beyond reputeDuane996tt has a reputation beyond reputeDuane996tt has a reputation beyond reputeDuane996tt has a reputation beyond reputeDuane996tt has a reputation beyond reputeDuane996tt has a reputation beyond reputeDuane996tt has a reputation beyond reputeDuane996tt has a reputation beyond reputeDuane996tt has a reputation beyond reputeDuane996tt has a reputation beyond reputeDuane996tt has a reputation beyond repute
Originally Posted by waipahu996
1. Remove lug nuts
2. Remove wheel.
5. Remount wheel.
As long as the wheels are off, wash the insides of them out too.
Jul 29, 2019 11:13 AM
DonBond
Apr 16, 2016 07:55 PM
Sep 1, 2015 03:16 PM
ECS Tuning - VW
Aug 19, 2015 08:58 AM
