Coolant problem
Old Jan 7, 2008 | 11:11 AM
JSmith5690's Avatar
JSmith5690 is infamous around these parts
Coolant problem
Guys,
I am looking for a little help diagnosing my problem:
1. My 99 C2 had a small through hole leak in the lower hose because of a driveway scrape, so I replaced the hose about 1.5 months ago. Now it has a small continuing drip that appears to come fro the lower hase connection (no matter how tight the clamp is).
2. Even worse, since I replaced the hose my car periodically belches coolant from the expansion tank all over my engine bay. I drove the car with the relief valve on the expansion tank open for about two weeks (daily driver) and topped of the coolant to the appropriate level. It belches much more frequently if I drive with the relief valve in the closed position, so now I drive with it continously open yet it still spews coolant.
Any advice would be greatly appreciated.
Jeff
Old Jan 7, 2008 | 11:29 AM
paneraiwatches's Avatar
paneraiwatches is a splendid one to beholdpaneraiwatches is a splendid one to beholdpaneraiwatches is a splendid one to beholdpaneraiwatches is a splendid one to beholdpaneraiwatches is a splendid one to beholdpaneraiwatches is a splendid one to behold
Replace the plastic coolant tank. It's a common problem. Porsche has redesigned the part about 4 times to date.
Old Jan 7, 2008 | 11:36 AM
daytrader's Avatar
daytrader is infamous around these parts
Check hose end and clamp for proper install. Did you replace the old clamp? Also, leak can come from the main leak expansion tank.
The other problem sound like bad thermostate. I noticed you have a 99 C2 maybe it's time to replace the expansion tank. With older 996 this is a must.
Old Jan 7, 2008 | 12:46 PM
Extremespeed's Avatar
Extremespeed is infamous around these parts
It sounds like you have a couple different problems.
First, the coolant hose leak. If the hose fitting wasn't cleaned off good enough the coolant residue will leave a trail for coolant to come out. Also, often the flange gets scraped and causes the gasket to leak by the lower bolt.
Second, coolant comming from cap. This could be several things- stinking thermostat, bad coolant cap/cross threaded cap, and defective cooling fans /resistors. Any one of these could caust coolant to come out the cap.
Also, check the now hose for a kink.
Typically, a defective coolant tank has an external coolant leak that leaks onto the exhaust pipe on the drivers side.
I hope this helps
Old Jan 7, 2008 | 05:31 PM
JSmith5690's Avatar
Thanks to everyone for the suggestions.
Just to clarify, my car doesn't seem excessively hot when it blows. According my gauge, the needle is on the "0" of the '180" degree mark of the dial.
Does this narrow down my problem?
Thanks.
Old Jan 8, 2008 | 09:43 AM
daytrader's Avatar
With bad tank or rusty thermostate you won't get overheated. The fans will help with that. Go to a radiator shop and have them do a radiator pressure test. That will pinpoint the actual leaking area and if the thermostate is bad. Also, a good way to check your water pump, hoses too. GL!
Old Jan 8, 2008 | 07:03 PM
jungzilla's Avatar
jungzilla is infamous around these parts
I a similar problem with my car. It was a crack in the coolant tank. I got it replaced.
Old Jan 8, 2008 | 11:36 PM
JSmith5690's Avatar
Thanks for the suggestions.
Jeff
Old Jan 9, 2008 | 06:56 AM
PTarga's Avatar
PTarga is infamous around these parts
This is what I've always heard from the dealer, also. Replace the the most likely cause first.
Old Jan 17, 2008 | 03:41 PM
farrbar's Avatar
farrbar is infamous around these parts
Has anyone hear replaced the tank themselves? If so, how hard was it?
Dealer said it was $950 (4 hours labor @ $150, plus $350 in parts ($300 for tank, $25 cap, and coolant). 4 hours seems like a really long time, but I am guessing that is "book time" . I found the tank for $185 on-line.
Old Jan 18, 2008 | 09:32 AM
daytrader's Avatar
WHAT! That's highway robbery. My indy charged $350 for part & labor.
There is a DIY on Renntech. GL!
Old Jan 18, 2008 | 04:57 PM
porsche-t's Avatar
porsche-t is infamous around these parts
I replaced the coolant tank on my '99 in about an hour (it took that long because I stopped for two beers).
Old Jan 19, 2008 | 01:01 AM
Chuck Jones's Avatar
Chuck Jones has a reputation beyond reputeChuck Jones has a reputation beyond reputeChuck Jones has a reputation beyond reputeChuck Jones has a reputation beyond reputeChuck Jones has a reputation beyond reputeChuck Jones has a reputation beyond reputeChuck Jones has a reputation beyond reputeChuck Jones has a reputation beyond reputeChuck Jones has a reputation beyond reputeChuck Jones has a reputation beyond reputeChuck Jones has a reputation beyond repute
I'm not a master mechanic by any means, but using the DIY explanation and pictures from RennTech, and there may be a similar posting on Pelican or Rennlist (do a search for coolant tank)....I did it in about 1.5 hours....hardest part was wiggling the tank out of a rather confined space, then wiggling the new one back in without breaking the sensor on the bottom. Not rocket science, but it did bring out some rather colorful adjectives from my vocabulary.
Saint Ari
Jan 17, 2022 09:22 PM
targa03
Sep 14, 2015 11:54 AM
Yogi911
Sep 9, 2015 08:20 PM
