TechArt Rear Wing Issue
Old Jun 12, 2004 | 10:06 AM
burnr8's Avatar
burnr8 is infamous around these parts
So I bought my '00 with the TechArt wing already on, but when they did the install they never disabled the trouble light for wing the wing articulates above 65mph(I think)....does anyone know a work around to keep the light off? The red glow is making me nutty! Thoughts I have had is pull the dash and unplug the light, yank the fuse if it only is for the light, or do a loop back for the switch in the engine comp......but before I blaze a trail and reinvent the wheel, I was wondering if others have run into this?
Thanks a ton....and this board ROCKS!
Old Jun 12, 2004 | 11:22 AM
CA996's Avatar
CA996 is infamous around these parts
Tom at Lucent did mine by rewireing something in the engine compartment. He bypassed something and my light has never come one.
Old Jun 12, 2004 | 01:32 PM
burnr8's Avatar
that is almost like teasing....but it is a start....I think a closed circuit on that switch should shut off the light.....or pop the fuse...time to take the plunge.....I will post on the outcome
Old Jun 13, 2004 | 12:55 AM
CA996's Avatar
Call Tom At Lucent I'm sure he has the wiring diagram to bypass the light. Good Luck.
Old Jun 14, 2004 | 10:22 PM
alexskee's Avatar
alexskee is infamous around these parts
Burner,
I posted a wing problem several months ago and was able to fix the same problem. Go to search and type in c4s wing and you will find my post. all you have to do is just replace the wiring harness with part number 996 612 07051. It's a plug and play. Should take only 15 mins. Good luck.
Alex
Old Jun 14, 2004 | 10:37 PM
burnr8's Avatar
Thanks a ton!! That light was going to be the death of me! I appreciate the help.
Mackchacha
Jul 9, 2019 11:03 AM
3WDistributing
31
Oct 27, 2017 01:26 PM
undefnd
16
Aug 26, 2015 07:59 PM
