What are normal compression numbers for a 3.6 motor?
Old Mar 4, 2008 | 04:05 PM
PJF's Avatar
PJF
PJF is infamous around these parts
Also, what would be typical for the leak down figures? Finally, how much differential between cylinders would be considered OK? For example, if all cylinders had one compression reading and one was 10-15% lower than the other 5. Same thing on the leak down numbers. I am just trying to determine if the PPI leak down and compression numbers are good or not. Thanks for the feedback.
Pat
Old Mar 4, 2008 | 05:24 PM
demosan's Avatar
demosan is infamous around these parts
Pat
Pat,
As I recall compression numbers should be 160psi and deviation of any cylinder result should be no more than 10% max.
demosan
Old Mar 5, 2008 | 01:26 PM
propr`one's Avatar
propr`one is infamous around these parts
15% = problem. Put a little (15-20ML) of oil in the cylinder, pull the fuel pump fuse, crank it over a few times and try again.
if it keeps reading that low, you got a problem.
Old Mar 5, 2008 | 03:05 PM
1999Porsche911's Avatar
1999Porsche911 has a brilliant future1999Porsche911 has a brilliant future1999Porsche911 has a brilliant future1999Porsche911 has a brilliant future1999Porsche911 has a brilliant future1999Porsche911 has a brilliant future1999Porsche911 has a brilliant future1999Porsche911 has a brilliant future1999Porsche911 has a brilliant future1999Porsche911 has a brilliant future1999Porsche911 has a brilliant future
General rule of thumb is 18 -20 times your compression ratio on a good and warm engine.
rzmnco
Cayenne 955/957
Oct 7, 2025 03:12 PM
Hybrid
Jun 28, 2024 06:05 AM
Abuong01
930 Turbo
Sep 15, 2015 01:05 PM
Suds26
Sep 2, 2015 01:33 PM
