Leak down/ compression check done. I need help analyzing the results.
Old Mar 5, 2008 | 01:00 PM
PJF's Avatar
PJF
PJF is infamous around these parts
Well, the test came back with between 17% and 19% leak down on 5 cylinders and 25% on cylinder one. Also, the compression was in the 220 range on the 5 cylinders and the 195 range on cylinder 1. Should I run and not wall away from this car with these numbers. Several Porsche techs said that for a road car, the difference is not that big of a deal. Is that true? Please someone give me an honest appraisal of this situation. Also, if you liked the car in all other respects, how much would this situation warrant the price to be reduced by? Thanks in advance for your feedback.
Old Mar 5, 2008 | 04:32 PM
Mother's Avatar
Mother is infamous around these parts
To much difference for me on cyl 1, look around.
Old Mar 5, 2008 | 09:55 PM
Springgeyser's Avatar
Springgeyser is infamous around these parts
If the leakdown is done correctly, the engine is on its way out or already junk. PASS.
5-8% across all cylinders is good.
Old Mar 6, 2008 | 06:13 PM
millennium911's Avatar
millennium911 is infamous around these parts
I agree. Years ago BMW had a bunch of bad engines and they would replace them if one or more cylinders registered 15% or higher. Factor in a 10-12K engine replacement and if still a smoking deal (no pun intended) you might consider but I would walk away.
Old Mar 6, 2008 | 09:43 PM
MPD47's Avatar
Only 5SPEED
MPD47 is infamous around these partsMPD47 is infamous around these parts
Compression on #1 is out of range, and those leakdown numbers are appalling.
Old Mar 6, 2008 | 11:36 PM
"Several Porsche techs said that for a road car, the difference is not that big of a deal."
And I would not go to these Porsche technicians.
Old Mar 7, 2008 | 09:54 PM
Duane996tt's Avatar
Duane996tt has a reputation beyond reputeDuane996tt has a reputation beyond reputeDuane996tt has a reputation beyond reputeDuane996tt has a reputation beyond reputeDuane996tt has a reputation beyond reputeDuane996tt has a reputation beyond reputeDuane996tt has a reputation beyond reputeDuane996tt has a reputation beyond reputeDuane996tt has a reputation beyond reputeDuane996tt has a reputation beyond reputeDuane996tt has a reputation beyond repute
Run Forrest, Run
rzmnco
Cayenne 955/957
Oct 7, 2025 03:12 PM
PV=nRT.
Sep 9, 2022 06:06 PM
Paintballzen
Oct 10, 2020 12:22 PM
DLF
Cayenne Turbo
Oct 24, 2015 11:27 AM
AuZZie
Sep 2, 2015 04:26 PM
