Sunroof problems ?
Old Apr 29, 2008 | 08:18 PM
porshaah's Avatar
porshaah is infamous around these parts
Angry Sunroof problems ?
I have taken my car to the local dealer 3 times with the same issue.the sunroof closes 3/4 of the way then it goes back to the open position.it only closes with the button fully depressed.
Dealer said there is nothing wrong with it & simply added heavy grease.After the 3rd time & the issue is still present,what should i do now that my warranty will expire in 3-4 months?
Any advise will be appreciated guys..
Old Apr 29, 2008 | 09:59 PM
SLVR_BULLIT's Avatar
SLVR_BULLIT is infamous around these parts
Mine does that too sometimes but only when it is really windy or at high speeds. I would say I havent determined the true root cause, but it is infrequent and irritating. I wish I had a better answer for you
Old Apr 29, 2008 | 10:11 PM
ELMEL's Avatar
ELMEL has much to be proud ofELMEL has much to be proud ofELMEL has much to be proud ofELMEL has much to be proud ofELMEL has much to be proud ofELMEL has much to be proud ofELMEL has much to be proud ofELMEL has much to be proud of
It's probably sensing resistance. It's a safety feature. Mine did this after I applied some foam pads to reduce noise. So I removed some of the foam pads and it worked fine. Check for obstructions. If there aren't any, your dealer should cover it under warranty.
Old Apr 29, 2008 | 11:10 PM
CaRJoE0220's Avatar
CaRJoE0220 is infamous around these partsCaRJoE0220 is infamous around these parts
Search, this issue has been discussed.
Mine does it to. But the light flickers on and off so I think the my switch may be to blame. But others say its from gunk and dirt causing it to go back.
Old Apr 30, 2008 | 03:32 AM
JoelPirela's Avatar
JoelPirela has a reputation beyond reputeJoelPirela has a reputation beyond reputeJoelPirela has a reputation beyond reputeJoelPirela has a reputation beyond reputeJoelPirela has a reputation beyond reputeJoelPirela has a reputation beyond reputeJoelPirela has a reputation beyond reputeJoelPirela has a reputation beyond reputeJoelPirela has a reputation beyond reputeJoelPirela has a reputation beyond reputeJoelPirela has a reputation beyond repute
It's the sunroof supposed to be really slow?
To be honest with you guys, I can't figure it out to make it work, even after reading the manual. One touch opening? never worked for me. Do you need to tilt open to open the sunroof? The dealer said the same story here. There's nothing wrong with it. I gave up and assumed I don't have a sunroof. keep it closed at all times. What a solution!
Old Apr 30, 2008 | 08:45 AM
dcentric's Avatar
dcentric is a jewel in the roughdcentric is a jewel in the roughdcentric is a jewel in the roughdcentric is a jewel in the rough
It's due to the fact that Porsche spends all their time engineering performance, and things like sunroof switches get no attention from their engineering dept
Old Apr 30, 2008 | 09:20 AM
JoelPirela's Avatar
you are not kidding!
This is an engine+transmission+wheels meant to go fast.
Anything else it's an afterthought! :P
Old Apr 30, 2008 | 09:55 AM
dcentric's Avatar
including the cumbersome huge chuck of the center console that they've ingeniously assigned to holding four CDs.
Old Apr 30, 2008 | 04:45 PM
ELMEL's Avatar
Try a different dealer.
Old Apr 30, 2008 | 08:44 PM
porshaah's Avatar
Its off to the dealer............thanks!
Old May 1, 2008 | 11:28 AM
MCM97's Avatar
MCM97 is a splendid one to beholdMCM97 is a splendid one to beholdMCM97 is a splendid one to beholdMCM97 is a splendid one to beholdMCM97 is a splendid one to beholdMCM97 is a splendid one to beholdMCM97 is a splendid one to beholdMCM97 is a splendid one to behold
It's the switch. $53 + tax. Make sure the dealer doesn't break the panel tabs when they put it in. If they do you'll be waiting 4-5 business days for it to come in. Ask me how I know!
JWrightPNH
Nov 9, 2015 03:44 PM
jaehoppa
Oct 22, 2015 09:17 PM
Wheeler
Sep 22, 2015 08:02 PM
