Help Check Engine Light
Old May 28, 2008 | 04:38 PM
asialors996's Avatar
asialors996 has a spectacular aura aboutasialors996 has a spectacular aura aboutasialors996 has a spectacular aura about
HELP!!!
Just got in my car and the CE Light came on. Scanned it and it came up 0172 System too Rich(Bank 1)
Car idles up and down til you rev it then it smooths out.
HELP!!!
Old May 28, 2008 | 08:11 PM
wross996TT's Avatar
Oxygen Sensing Adaptation, Idle Range, Bank 1 –
Below Limit
Possible fault cause
♦ Incorrect signal from MAF sensor
♦ Fuel pressure too high
♦ Fuel injector leaking
♦ EVAP canister purge valve open
my guess is MAF
Old May 28, 2008 | 09:10 PM
thanks...that seems logical i have a K&N kit that has been in there for a year so i dont think that is the cause perhaps just miles...I reset the CEL and im going to try some MAF cleaner tomorrow...
Old May 30, 2008 | 08:50 AM
im goingto try some of that CRC MAF Cleaner...any thoughts??
Old May 30, 2008 | 10:05 AM
daytrader's Avatar
daytrader is infamous around these parts
I don't see any wrong doing by using the cleaner on the MAF. From time to time, I do remove the MAF and clean it with electronic cleaner. I just did a week ago. Also, I do have K&N intake too!
Old May 30, 2008 | 12:09 PM
Flyer007's Avatar
Flyer007 is infamous around these parts
Daytrader how many miles on the K&N?
Old May 30, 2008 | 12:40 PM
daytrader's Avatar
I think little more than 5K miles with a lot of aggressive driving. Why?
Old May 30, 2008 | 01:20 PM
Flyer007's Avatar
Just bought a used one off our marketplace.....
Read plenty of threads but figured I'd ask you also. Thus ballparking the supposed MAF issue.
Old May 30, 2008 | 02:16 PM
daytrader's Avatar
Listen, that what I was afraid before I bought it. Found out later that MAF issue was involve with TT not NA. On top of that owners over sprayed oil cleaner on the filter. I have no problem since installed which involved many miles aggressively driving with the car. I only lightly oiled the filter every time I washed it.
tropicatango
Jun 8, 2025 01:00 PM
Mini George
Jul 29, 2019 12:20 PM
Mini George
Jan 18, 2016 09:16 PM
The Oss
Aug 24, 2015 08:19 PM
