Getting a clunk kind of sound from the front. what could it be?
Old Jul 17, 2008 | 02:59 PM
yellowbmr's Avatar
yellowbmr is just really niceyellowbmr is just really niceyellowbmr is just really niceyellowbmr is just really niceyellowbmr is just really nice
The only after market item in the front of the car was the PSS9 that was installed by Lucent. Could the PSS9 be the problem (being loose) or is it something else ?
I want to see if there is any known clunk kind of sound from the front of 996's.
The noise can be heard at low speeds (1-2mph), backing up or just driving forward. Turning the steering while driving at 1-2mph also can duplicate the clunk sound.
Please advise.
Thanks.
Old Jul 17, 2008 | 06:33 PM
mathism's Avatar
mathism has a reputation beyond reputemathism has a reputation beyond reputemathism has a reputation beyond reputemathism has a reputation beyond reputemathism has a reputation beyond reputemathism has a reputation beyond reputemathism has a reputation beyond reputemathism has a reputation beyond reputemathism has a reputation beyond reputemathism has a reputation beyond reputemathism has a reputation beyond repute
Sounds like a suspension problem. I'm not aware of any "known" clunk issues. If you just had the PSS9 installed, that is the likely culprit.
Old Jul 17, 2008 | 06:36 PM
Redridge's Avatar
check your drop links, they are loose
Old Jul 18, 2008 | 06:57 AM
every day's Avatar
every day is infamous around these parts
Ditto on the drop links/sways - very common issue. Was the install done recently?
Old Jul 18, 2008 | 07:16 AM
perryinva's Avatar
perryinva is infamous around these parts
What/where exactly are drop links? Do you mean the links to the sway bars?
Old Jul 18, 2008 | 07:23 AM
every day's Avatar
Yes - links to the sways.
Old Jul 18, 2008 | 09:56 AM
yellowbmr's Avatar
I guess it calls for a visit to the dealer. The PSS9 was done by Lucent, and i didn't feel the clunk until a year later.
I hope dealer won't consider the PSS9 a warranty issue.
What do you guys think?
Old Jul 18, 2008 | 10:16 AM
every day's Avatar
Check the links first, they are known to come loose occasionally. If they're tight, then try a local shop unless you're still under warranty - which you may have voided with pss9's.
Old Jul 18, 2008 | 10:20 AM
every day's Avatar
Just to be clear, the only reason I asked if they had been done recently is that Arling would probably have tighten the links and checked everything for little to no charge. The links could easily have come loose a year later - vibrations, impact with a pothole, etc...
If your problem is in any way tied to or is a result of the pss9's, then you won't have any warranty coverage.
Old Jul 18, 2008 | 10:21 AM
fotostars's Avatar
fotostars has much to be proud offotostars has much to be proud offotostars has much to be proud offotostars has much to be proud offotostars has much to be proud offotostars has much to be proud offotostars has much to be proud offotostars has much to be proud of
That will sound stupid but a friend had some clunking noise in the front and it turned out to be the tire pressure was in the mid 20' ... Just a thought...
Old Jul 18, 2008 | 11:01 AM
yellowbmr's Avatar
is it easy to get to the droplinks once the car is jacked up?
Is it a matter of just tightening the bolts?
Also, gonna check the tire pressure, haven't done it for a while.
Old Jul 19, 2008 | 04:47 PM
Dervish's Avatar
Dervish is infamous around these parts
I've got the same issue, just had GT3 sway bars and AP droplinks fitted and driving home just now noticed a clunk at low speed, if it is the drop links do I just tighten till ther's no nut movement or do they need torqued?
Old Jul 19, 2008 | 09:32 PM
Redridge's Avatar
some loctite will help... hand tighten is fine.
Old Jul 20, 2008 | 05:46 AM
Dervish's Avatar
Thanks, took the wheels off this morning and it was these nuts in the picture that were loose, is that what everyone else found? Nothing else seemed wrong so tightend those down not altering the drop link length...
Old Jul 21, 2008 | 02:29 AM
Dervish's Avatar
Clunking is still there!!!? Is this a generic fault with adjustable drop links? Been told by installer they had the same problem and already tightened once before. They're suggesting moving to the non adjustable OEM drop link which they fit to all they're race/ road GT3s.
This is pi55ing me off not to mention my wallet!
