I need maintenance advice please.
Old Nov 9, 2008 | 01:55 PM
qcraftsman's Avatar
qcraftsman is infamous around these parts
99 C2. Just bought it with 69K miles. I am worried about these horror stories. Owner said he did all maintenance, but just in case is there a major tune up job that should be done at 69K miles? any suggestions...
Old Nov 9, 2008 | 02:59 PM
qcraftsman's Avatar
any suggestions please..
Old Nov 9, 2008 | 03:22 PM
deckman's Avatar
Did you get maintenance records when you bought the car? Did you get a pre purchase inspection? If the owner did all the maintenance, the last scheduled one was due at 60k, which is a bigger one.
Old Nov 9, 2008 | 04:11 PM
qcraftsman's Avatar
Well I bought the car wrecked so I had my body guy over look it. He fixes exotic cars for a bodyshop here in Rockville, MD. What is due to be done at 60K???
Old Nov 9, 2008 | 05:47 PM
win911's Avatar
win911 has much to be proud ofwin911 has much to be proud ofwin911 has much to be proud ofwin911 has much to be proud ofwin911 has much to be proud ofwin911 has much to be proud ofwin911 has much to be proud ofwin911 has much to be proud ofwin911 has much to be proud of
When I did my 60k service... I did the following
oil and filter change
transmission fluid
front differential fluid (C4)
spark plugs
serpentine belt
bleed brake fluid
bleed clutch fluid
changed my rear deck lid shocks...it was bad
cleaned throttle valve
checked suspension components, exhaust, and everything else underneath the car
Hope this helps..
Old Nov 9, 2008 | 06:09 PM
Lerxst's Avatar
Lerxst is infamous around these parts
Renntech.org has the maintenance schedule for the car.
JQGS
Oct 18, 2015 06:19 PM
saiko88
Sep 11, 2015 02:17 PM
