brake wear sensor
Old Dec 19, 2008 | 09:38 AM
rpf996's Avatar
rpf996 is infamous around these parts
brake wear sensor
Has anyone experienced a problem with brake sensor/brake wear indicator malfuntioning? I have experienced this when washing the car on several occasions. I recently had the sensors replaced and the problem is manifesting itself again. 2002C2.
Old Dec 19, 2008 | 10:47 AM
mathism's Avatar
mathism has a reputation beyond reputemathism has a reputation beyond reputemathism has a reputation beyond reputemathism has a reputation beyond reputemathism has a reputation beyond reputemathism has a reputation beyond reputemathism has a reputation beyond reputemathism has a reputation beyond reputemathism has a reputation beyond reputemathism has a reputation beyond reputemathism has a reputation beyond repute
I've never had a problem with it. If you had the sensor replaced at a shop, I'd take it back for further diagnosis.
Old Dec 19, 2008 | 11:12 AM
Zookie's Avatar
When my lights came on at the Track (First Time at the Track). I was told that it probaly got Fried due to Heat... This is Common... I did not do anythign about it for a month or two... Whenever i would wash my car the light would go away untill the brakes heated up, then the light came back on... eventully my front pads were done and i replaced all four pads and sensors...
Old Dec 19, 2008 | 11:41 AM
rpf996's Avatar
Thanks for the response guys, I should have added the rotors & pads are new. I was wondering if there might be any underlying electrical problem, or if the problem is in one of the sensors.
Old Dec 21, 2008 | 09:41 PM
Redridge's Avatar
if you keep an eye on your pads, just soder the sensor wires together and put shrink wrap on , no more lights ever...
Old Dec 21, 2008 | 09:46 PM
Purplxd's Avatar
Purplxd has much to be proud ofPurplxd has much to be proud ofPurplxd has much to be proud ofPurplxd has much to be proud ofPurplxd has much to be proud ofPurplxd has much to be proud ofPurplxd has much to be proud ofPurplxd has much to be proud of
I keep an eye on everything all the time with my car, so next time I'll be doing that with the sensors.
I too replaced my rotors, pads, and sensors and when washing the car get the light at times and it eventually goes away. It's more than likely something in the actual connection where the sensor plugs in... not in the pad, the other end.
Classic clean out of the connection points very well with brake clean and a small bit of emery cloth would probably make the connections better and get rid of this issue.
Just a thought...
Cheers
Aaron
Old Dec 23, 2008 | 06:21 AM
Redlined's Avatar
Redlined has a spectacular aura aboutRedlined has a spectacular aura about
Redridge nails it, esp with a track car. +1
Old Dec 23, 2008 | 11:18 AM
rpf996's Avatar
Good info guys, apppreciate it.
J9277655
Dec 28, 2015 11:01 PM
henryr
Sep 24, 2015 08:22 PM
Jaytaylor10485
Aug 28, 2015 06:25 AM
LiquidElephant
Aug 27, 2015 06:17 PM
