Window isn't doing that dip thing when I open the door...
Old Dec 25, 2008 | 01:58 AM
paki's Avatar
paki is infamous around these parts
I had the same problem in the cold. I just pushed the top of the window while warming up the car and it was fine.
Old Dec 25, 2008 | 09:22 AM
NIKAS's Avatar
NIKAS is infamous around these parts
My apologies, they're now $179.40 at Suncoast E-parts, a 6SO sponsor. Code: 99654207504 (driver), Code: 99654207604 (passenger).
Old Dec 27, 2008 | 06:39 AM
DFC's Avatar
DFC
DFC is infamous around these parts
If you decide to do it yourself, remember to remove the top window stop, otherwise the window will not go down all the way. BTW, I paid around $165 over the summer at Sunset Imports in Oregon.
Old Dec 27, 2008 | 06:45 AM
deputydog95's Avatar
deputydog95 Is a GOD !deputydog95 Is a GOD !deputydog95 Is a GOD !deputydog95 Is a GOD !deputydog95 Is a GOD !deputydog95 Is a GOD !deputydog95 Is a GOD !deputydog95 Is a GOD !deputydog95 Is a GOD !deputydog95 Is a GOD !deputydog95 Is a GOD !
I"ll probably just have the dealer do it. It's got to go in for something else anyway next week. Thanks for all the info!
Old Dec 29, 2008 | 01:47 PM
stanm5's Avatar
stanm5 is infamous around these parts
Same thing happened with my '02 cab recently. After all the tests it was determined to be the micro switch that's part of the latch mechanism. Unfortunately that micro switch can't be replaced on it's own; had to replace the latch.
Good luck.
Old Dec 29, 2008 | 10:30 PM
josh@iautohaus's Avatar
josh@iautohaus is a jewel in the roughjosh@iautohaus is a jewel in the roughjosh@iautohaus is a jewel in the rough
Yup I second the regulator, the regulator cable is streched out to far and when it sees a signal from the micro switch in the door handle and pulls on the regulator and just pulls slack in the cable and wont pull the regulator/window down to avoid the door seal.
Old Dec 31, 2008 | 03:08 PM
dreamtripper's Avatar
dreamtripper is infamous around these parts
Had this happen when I had my 02 Carrera also and it turned out the latch needed to be replaced. Cost something like $700 parts and labor at the dealer.
Good luck.
Old Dec 31, 2008 | 03:55 PM
Got my car back today. Came out to $360 parts and labor. The window reg was shot.
Old Nov 11, 2009 | 07:49 PM
Hunnicuttz's Avatar
Hunnicuttz is infamous around these parts
What shop did you go to? I'm also in Florida, hopefully close haha.
Old Nov 11, 2009 | 08:02 PM
rvhpno80's Avatar
rvhpno80 Is a GOD !rvhpno80 Is a GOD !rvhpno80 Is a GOD !rvhpno80 Is a GOD !rvhpno80 Is a GOD !rvhpno80 Is a GOD !rvhpno80 Is a GOD !rvhpno80 Is a GOD !rvhpno80 Is a GOD !rvhpno80 Is a GOD !rvhpno80 Is a GOD !
off topic, i love this avy, it reminds me of my 02 996 cab..... nice ride...
Old Nov 12, 2009 | 04:37 AM
I'm in Clearwater and I went to Vortex motorpsorts.
Old Nov 12, 2009 | 08:41 PM
Hunnicuttz's Avatar
Thank you!
Old Nov 14, 2009 | 02:46 PM
Trent's Avatar
Trent is infamous around these parts
Happened on my Boxster last year, was the window regulator.. Had a friend install it for me, as the dealership wanted a bit much..
Old Aug 17, 2010 | 05:31 PM
max996's Avatar
max996 is infamous around these parts
Info
Do not want to start confusing the tread, read this tread with great interest since my window started to go down when I toched the outside door handle, but then right the way went back up after releasing the handle.
Same thing would happen when engaging the inside door handle.
Checked both door handle micro switches, both are working as it should.
Culprint, in the door latch, the engagement latch was sticky, sprayed silicone/lube spray into it and the system works like new, no need to remove the latch and or micro switch, took all but 2 minutes from the outside.
Hope this could save someone some time, worth a try.
Regards
Max
Tremelune
Oct 22, 2019 06:12 PM
Jul 29, 2019 11:13 AM
r_matt_6
Oct 8, 2015 06:07 PM
The Oss
Aug 24, 2015 08:19 PM
