Got check engine light (CEL)... I can help..
Old Feb 1, 2009 | 03:43 PM
Beans's Avatar
Beans is infamous around these parts
I have a 99 C4 Cab w tip trans and CEL just came on. Im in So Cal Please advise
Old Feb 1, 2009 | 08:02 PM
win911's Avatar
win911 has much to be proud ofwin911 has much to be proud ofwin911 has much to be proud ofwin911 has much to be proud ofwin911 has much to be proud ofwin911 has much to be proud ofwin911 has much to be proud ofwin911 has much to be proud ofwin911 has much to be proud of
Beans...
You got a pm.
Old Feb 4, 2009 | 08:19 AM
Cajundaddy's Avatar
Cajundaddy is infamous around these parts
Originally Posted by BMoney5327
I got a check engine light on..but im in NJ damnn...But question..With a CEL bein on and you not knowing the problem and the car was driving fine but now doesnt start,no click..but everything comes on..What the hell does that sound like the problem is?? Ehh
Bad ign. switch (common), battery cable or connectors, rodent chewed your wiring (it happens), blown fuse, bad alternator, bad starter. Process of elimination needed.
Old Feb 4, 2009 | 09:21 AM
Redridge's Avatar
+1... durametric are built for Porsches,
The others are just to generic... plus, the airbag reset is a godsend if you like to do DIY's.
Originally Posted by win911
Wrong... already compared it to the generic readers. Those readers are only good to a certain extent in regards to Porsches. That is why I bought the duramteric.... did my research before. I have both and the durametric shows more codes when compared to my generic.
As for the airbag lights with the generic reader... forget it. Can't even read those.
bmoney..
Sounds like an alternator..
Old Feb 4, 2009 | 08:50 PM
carsareart's Avatar
carsareart is infamous around these parts
CEL came on tonight. Evap Emission Control System Leak (large) code PO 455
1999 996, tiptonic, 118miles, New gas cap from local dealer back in Dec. the first time the light came on.
CEL came on in DEC, then Jan, 7th and then again tonight. same code, cleared with a code reader borrowed from my brother.
Next step???
Old Feb 4, 2009 | 08:59 PM
Redridge's Avatar
Next step???
Other possible problems:
vaccum leak in the EVAP system in or around the canister.
faulty pressure sensor on the top of the gas tank
Old Feb 4, 2009 | 09:03 PM
carsareart's Avatar
Thanks for the fast reply.
Looks like I have a weekend project.
Old Feb 6, 2009 | 05:40 PM
uberpoop's Avatar
uberpoop has a reputation beyond reputeuberpoop has a reputation beyond reputeuberpoop has a reputation beyond reputeuberpoop has a reputation beyond reputeuberpoop has a reputation beyond reputeuberpoop has a reputation beyond reputeuberpoop has a reputation beyond reputeuberpoop has a reputation beyond reputeuberpoop has a reputation beyond reputeuberpoop has a reputation beyond reputeuberpoop has a reputation beyond repute
win911- does your offer still stand? PMing
Old Feb 7, 2009 | 07:51 PM
win911's Avatar
Yes it still available....
Old Feb 10, 2009 | 09:36 PM
2fas4u's Avatar
2fas4u is infamous around these parts
Exclamation ignition
My guess is the ignition switch, which is also referred to as the ray gun. easy fix hour tops, if when it says nothing all the lights work and the horn blows it's the switch. good luck!
Old Mar 30, 2012 | 10:33 PM
jayi836's Avatar
jayi836 is infamous around these partsjayi836 is infamous around these parts
Airbag light
I just had my steering wheel refinished and i have the air bag light on after i re-installed it. do you still have the software and can you help out. in So Cal.its a 99 C2 Cab.
Old Mar 31, 2012 | 08:10 AM
win911's Avatar
Sure....pm sent.
Old Mar 31, 2012 | 09:33 AM
jayi836's Avatar
Smile Airbag light
Win911 thanks for the reply I'm in Simi Valley and work in Santa Monica i don't have enough post to DM you.let me know what works for you. i just got my C2 back in 4 wheels and running after minor restoration.
Old Mar 31, 2012 | 09:39 AM
win911's Avatar
Here's my email... winmotors@yahoo.com
Old Apr 23, 2012 | 07:52 AM
jp911turbo's Avatar
jp911turbo is infamous around these parts
where can i have deffinition for code p1601, p1671, m2101, l48
tropicatango
Jun 8, 2025 01:00 PM
Mini George
Jul 29, 2019 12:20 PM
Mini George
Jan 18, 2016 09:16 PM
oddjob142
Aug 24, 2015 05:49 PM
