996 water pump
Old Feb 27, 2009 | 09:49 AM
FLpaindoc's Avatar
FLpaindoc is a jewel in the roughFLpaindoc is a jewel in the roughFLpaindoc is a jewel in the rough
996 water pump
I need a new water pump. I saw a few drops of coolant on the garage floor. I can tell is comming from the water pump. My mechanic is charging me $800.00. Is that a fair price?
Old Feb 27, 2009 | 12:29 PM
GREERJ1's Avatar
GREERJ1 is infamous around these parts
What is the labor component and what is the parts component. Water pump and gasket should be around $300, the coolant should be recycled, $500 labor sounds a bit high. This is an easy job on the 911, just remove the air box and there is the water pump. You can sit down while your doing it, well, most of it.
Jim Greer
Old Feb 27, 2009 | 01:29 PM
FLpaindoc's Avatar
About 500.00 for labor. This is at an inde, not the dealer. I call the dealler and they quote was about 50.00 more.
Old Feb 27, 2009 | 02:01 PM
aben8057's Avatar
aben8057 is infamous around these parts
DIYer
Old Feb 28, 2009 | 12:23 AM
orangec2's Avatar
orangec2 is infamous around these parts
You can use this site to help estimate cost.
http://www.driverside.com/servicing/...00-3013-6241-0
Old Feb 28, 2009 | 08:19 AM
TraderJoe's Avatar
TraderJoe is infamous around these parts
I priced out $284 for the water pump and $425 for labor with an inde.
nlakind
Nov 6, 2015 10:15 AM
turbotuner20v
Sep 11, 2015 12:02 PM
LiquidElephant
Aug 27, 2015 06:17 PM
