What other engines will work for my 99 C2?
Old Apr 20, 2009 | 09:11 PM
qcraftsman's Avatar
qcraftsman is infamous around these parts
99 C2, just curious if it happens and I need to do so what other porsche engines will go into my car? Turbo?
Old Apr 20, 2009 | 09:19 PM
LowStro9's Avatar
LowStro9 is infamous around these parts
Flame me as you wish....but if mine goes, I am going to an n/a 800hp LS1. And I already have the wiring transformation pretty much resolved.
Old Apr 20, 2009 | 09:25 PM
C70Pete's Avatar
C70Pete is infamous around these partsC70Pete is infamous around these partsC70Pete is infamous around these partsC70Pete is infamous around these parts
whatever you do other than a 3.4 its gonna be big $$$ for the conversion... a 3.8 would be ideal for your car...
Old Apr 20, 2009 | 09:49 PM
DsoVIP's Avatar
DsoVIP is infamous around these parts
i like the idea! how hard is the swap?
Old Apr 20, 2009 | 09:55 PM
C70Pete's Avatar
its involved.... you'll need the following in addition to a healthy 3.8:
3.8 rear harness ($$$)
2002 + 3.6 ECU
2002 +e-gas pedal
2002+ 3.6 instrument cluster
2002 + fuel sending unit
check out www.fvd.com they do the conversion for like $25 USD... its not cheap... but your car is gonna fly when its done... you should be as fast as a MKII GT3... (strait line only)
Old Apr 20, 2009 | 10:04 PM
iJeremy's Avatar
iJeremy Is a GOD !iJeremy Is a GOD !iJeremy Is a GOD !iJeremy Is a GOD !iJeremy Is a GOD !iJeremy Is a GOD !iJeremy Is a GOD !iJeremy Is a GOD !iJeremy Is a GOD !iJeremy Is a GOD !iJeremy Is a GOD !
It's usually more a question of which motors will fit your wallet than which will fit your 996. With enough $$ you can shove nearly anything back there.
Old Apr 20, 2009 | 10:19 PM
MCM97's Avatar
MCM97 is a splendid one to beholdMCM97 is a splendid one to beholdMCM97 is a splendid one to beholdMCM97 is a splendid one to beholdMCM97 is a splendid one to beholdMCM97 is a splendid one to beholdMCM97 is a splendid one to beholdMCM97 is a splendid one to behold
Mike it took you 8 minutes to suggest the LS1 swap. You're getting slow in your old age
Old Apr 21, 2009 | 01:04 AM
DsoVIP's Avatar
that should be okay since I have an 02 right
2002 + 3.6 ECU
2002 +e-gas pedal
Old Apr 21, 2009 | 03:07 AM
Dom9's Avatar
Dom9 is infamous around these parts
I spoke with renegade last year and i was under the impression that an LS1 would not fit as the engine bay is smaller in the 996 compared to the earlier, air cooled cars.
I was wondering whether a tuned Subaru H6 might work in N/A form or a Subaru WRX Turbo flat-4. I looked quite hard into the conversion and I reckon I could get the engine in fine, the problem may be the 'box/ starter but that may be solved at some point...
As it is, if my engine ever pops (and lets hope it doesn't) then i woudl likely go to Autofarm in the UK (who look after my car anyway) and get the (supposedly) bullet proof 3.7 conversion. I don't think any other solution would work out cheaper. Either that or get a machine shop over here to machine my case for Nickies liners and rebuild the engine myself, for a larger capacity with the IMS and cylinder upgrades.
Hello by the way - This is my first post, despite being a lurker for over a year!
Old Apr 21, 2009 | 08:14 AM
my996's Avatar
1999 C4 Cab 6 Speed
my996 is infamous around these parts
I hope that's not true because having an LS1 in there sounds so appealing to me.
As it is, if my engine ever pops (and lets hope it doesn't) then i woudl get the (supposedly) bullet proof 3.7 conversion. I don't think any other solution would work out cheaper.
Just confirming, did you mean to say 3.8? I am not aware of a 3.7 or I must be missing something.
WELCOME!
check this out - a 993 with LS1
http://forums.pelicanparts.com/showthread.php?t=461502
Old Apr 21, 2009 | 08:45 AM
Dharn55's Avatar
Dharn55 has much to be proud ofDharn55 has much to be proud ofDharn55 has much to be proud ofDharn55 has much to be proud ofDharn55 has much to be proud ofDharn55 has much to be proud ofDharn55 has much to be proud ofDharn55 has much to be proud ofDharn55 has much to be proud of
Upgrading to a 3.6 is not that big a deal. Roock in Atlanta does them, it cost about $2,000 or so more than a straight 3.4 swap. But the price of a 3.6 remanufactured from Porsche is about $8,400 vs $11,050 for a 3.4, there is a different core charge that cost a few hundred dollars. So the price difference for the engine pretty much covers the additional cost for the 3.4 to3.6 swap.
Old Apr 21, 2009 | 11:38 AM
Dom9's Avatar
Have a look here chaps:
3.7 from a 3.4 or 3.9 from a 3.6:
http://www.autofarm.co.uk/engines/water_cooled/capacity
They have the IMS upgraded and thicker walled cylinders, so they are a significant step up from a Porsche re-man or new engine, in theory at least. They have built a Cayman RS with the 3.7 engine which has been very well received on this side of the pond. I had a look a few weeks back when I was up there, almost (a very real) 100bhp/litre from an M96 and a gorgeous throaty roar.
Still, I reckon, if you could solve the starter motor issue, the Scooby WRX engine might be cheaper as a replacement.
Old Apr 23, 2009 | 12:04 PM
pearl_porsche's Avatar
pearl_porsche is infamous around these parts
I'm planning to upgrade my 99 to 3.8. I'm looking for the piggy to make wire to E-gas. I've heard cost around $1500 to buy those.
Old Apr 23, 2009 | 03:44 PM
Dharn55's Avatar
Again, talk to Fabian Roock. When I talked to him he said the upgrade from a 3.4 to a 3.8 was not that much more difficult than the 3.4 to 3.6. And a 3.8 reman is less expensive than a 3.4. the 3.6 X51 is also less than a 3.4. Porsche knows it has the 3.4 owners over a barrel, its disgusting!!
Old Apr 24, 2009 | 01:15 AM
Doc_Porsche's Avatar
Doc_Porsche is infamous around these partsDoc_Porsche is infamous around these parts
sounds awesome... i am also considering a 3.8 swap with my 3.4
